Old 10th November 2012, 01:38 PM
Numplumb Numplumb is offline
Default CP26 plates for MX5
Could someone give me dimensions for the rear diff hanger plates please, and is 3mm thickness okay?
Old 10th November 2012, 02:20 PM
will_08 will_08 is offline
Dont know about the exact dimensions but i think they are more like 5mm thick!
Old 10th November 2012, 02:42 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
I have used 3mm on mine once its welded up it seems strong enough
Will find out when it comes to driving though
Cant give dimensions atm as I am at work but all I did was measure where the diff would mount in the diff cage measured from mounting point to the outside edges of the cage and doubled it then measured from the seat back to the rear of the diff cage and cut steel accordingly
Hope that is of any use more to the point hope it makes sense
Old 10th November 2012, 02:52 PM
Thanks will 08 for your reply I was thinking that they should be thicker, the build guide for them says 3mm though but I think I will use 5mm as you suggest
It only gives dimensions for the hole spacing I was thinking of using 150mm x 361mm x 5mm plates as I can't see any reason why they need to be exact width
The 361mm is the same as RS7 any thoughts?.
Mick.
Old 10th November 2012, 03:00 PM
Thanks vmax1974 will try that
Old 10th November 2012, 03:08 PM
vmax1974's Avatar
Mick.
I think I overlapped the seat back by a few mil just to be sure
Old 10th November 2012, 03:19 PM
That's sounds like a good idea
I've PM Gillham about cp plates and have asked about these cp26 plates to get a rough price but haven't given them any sizes for them.
