Old 23rd December 2012, 05:23 PM
SeriesLandy's Avatar
Default PC help again
Hi guys, I'm having PC problems again, I've just installed a 2tb sata Harddrive in place of an old 320gb one but its not showing up in my computer. However it is in device manager.
Have you lot any ideas? Cheers
Its the ST2000 one.
Old 23rd December 2012, 05:58 PM
Go to Start, right click on my computer and select manage, then in the console select disk management, you should hopefully see your drive listed and you'l probably have to right click on it and select initialise.
Hope it helps
Old 23rd December 2012, 09:27 PM
Cheers mate, I'll give it a go tomorrow, I used to be good with IT, I'm rubbish now!
Old 23rd December 2012, 09:36 PM
No probs one other thing that might need checking depending on the age of the mobo is the sata data rate supported, you might need to limit the drive by the jumpers.
Post up how you get on
Old 23rd December 2012, 10:14 PM
The comp is either 2 or 3 years old. I'm putting the hard drive in my cctv dvr which is brand new but wouldn't show up on there either.
However the dead hard drive that I pulled out showed up.
Ill let you know how I get on.
Old 24th December 2012, 10:15 AM
Do they show in the BIOS?
Old 26th December 2012, 11:38 PM
did you get it sorted SL?
Old 27th December 2012, 12:07 AM
Tt yes it shows in the bios
Not had a chance yet with all the Christmas family stuff ect.
Hopefully I'll get a chance tomorrow.
Old 27th December 2012, 07:19 PM
Poped the HD in, did what you said it took 2 seconds and worked fine.
Pulled it back out, put it into the cctv recorder and it showed up straight away.
Thanks for the help I don't think I would have got it without. Damn Win7, XP was so easy
Old 27th December 2012, 07:31 PM
XP probably would have done the same with an un-initialised disk.
