Old 18th December 2012, 12:39 PM
It would be interesting to hear from anyone who has used an MX5 engine and gearbox but retained Sierra diff, front and rear uprights etc ? It would seem to be a practical transplant for an existing car.
Old 18th December 2012, 03:53 PM
Big Vern Big Vern is offline
You could do this but you would have no distinct donor and thus a q plate would be issued which is something some people get bent out of shape over.
If you go looking for a donor then why would you not use the running gear that came with it?
Old 26th December 2012, 07:53 AM
snapper snapper is offline
If you use Sierra diff, axle, hubs, brakes, steering rack & column the I believe you just about have enough points for an age related.
It's close and you should check
Old 26th December 2012, 07:11 PM
I was thinking more as a potential transplant for an existing car rather than the initial pre IVA build. When i was intending to build from scratch I would personally have gone for MX5 donor throughout.
Old 31st December 2012, 01:23 PM
If you have time to do it just add the correct engine number to the log book as an engine swap. Engine conversions are carried out on cars all the time , the installed engine becomes the correct one for the car. I cant see this as a problem, at the worst the dvla will want an engineers report or proof that its a sound installation which is only a paper pushing excercise.
