Old 15th January 2013, 08:07 PM
loony's Avatar
loony loony is offline
Little update...
In October I made build table...
My little helper...
Then I brought steel
Lucas
My build thread
Old 15th January 2013, 08:10 PM
loony's Avatar
And the battle with chassis began...
Lucas
My build thread
Old 15th January 2013, 08:13 PM
loony's Avatar
Front frame
I'm not happy with the result - I think I will have to make one again... but I'll see how it fit to the rest of chassis.
But it's cold outside, I'm sick (some kind of flu) so I orginised my work different
Lucas
My build thread
Old 15th January 2013, 08:19 PM
loony's Avatar
One guy from work has lathe, I draw some sketches and he did for me some parts:
Crush tubes, bush tubes... with DIY polyurethan bushes (I made them myself from two-component polyurethan resin)
It's just an example - I got whole set of them...
Front camber adjusters, sleeve tubes and rear camber tubes (?):
DIY sprocket adapter almost ready (SAE1140 flange)...
Need some welding...
... and then turning/balancing...
Tomorrow I plan to weld it but balancing/turning have to wait until water cooled lathe defrost and start to work again...
Next week I will have catalytic gas heater - maybe this would help keep me warm while building.
Lucas
My build thread
Old 15th January 2013, 09:34 PM
Looks like you have all the skills to make an excellent roadster
Looks good so far ,keep it up. The winter usually sorts the men builders from the boys
You may need a nuclear power plant in your garage for Polish winters
Old 15th January 2013, 10:24 PM
Originally Posted by loony View Post
Hoho, I think I recognize this layout
Good and rewarding to see that other people use it, and that this layout has not only been used once on my table. Still available from my Google documents
And it is still immaculate, it will not last
And by the way, you look to be doing a very good job, so congratulations. Polish winter should be at least as harsh as the Swedish one, and I have to confess I don't spend that much time in the workshop, so double congrats
Old 16th January 2013, 12:55 PM
I've got a full stainless steel exhaust system and manifold that would suit your car if you are interested ?
Cheers Dan
Old 17th January 2013, 07:37 AM
loony's Avatar
I thought you sold it with the engine...
It's all about the money I don't know how much it could cost in Poland to make one (probably much cheaper then in UK) and what's good deal for me.
Beside, I'm not sure if it suit my car/engine position (as to the right as possible) but with little modification should be OK.
Is this photo flipped or... I don't know how this fit zx9r
Do you have any photo of it on the car ? (I saw only your old manifold)
Lucas
My build thread
Old 17th January 2013, 04:13 PM
loony's Avatar
TIG welded DIY sprocket adaptor - ready for action
Lucas
My build thread
Old 25th January 2013, 08:37 PM
loony's Avatar
Last purchase:
10GBP - and only one problem - I got no key to ignition barrel... It would be my first barrel breaking in life
Genuine MOMO hub (K4524) - I tried it on my column and looks like it fits...
Apart that I already have Raid steering wheel (different PCD)... but for 6,40GBP - I couldn't resist... I'll have excuse to buy snap-off adapter
Next week I'll get another column - adjustable one and OEM Sierra steering wheel...
Lucas
My build thread
