Old 20th February 2013, 04:30 PM
Originally Posted by ayjay View Post
I am not sure a straight run from column to rack is a good thing. I think its a safety issue
Yes I thought that, but as I understand it if your using a modern column and it has safety features like being collapsable then that's fine. Quite clearly you don't want a solid rod of steel pointing at your bollocks so I've used 1mm walled steel tube and left a gap inside the tube between the upper mx5 shaft and lower escort shaft so it will hopefully buckle under impact.
I hope the above sounds sensible unless someone know otherwise, please let me know.
If you don't have a saftey column then the SVA want to see an indirect linkage of 3 or more UJs I think.
Old 20th February 2013, 08:27 PM
Dualist's Avatar
Dualist Dualist is offline
I would still put another UJ in there if it was pointing at my nuts, 1mm tube still hurts especially if it's traveling in a straight line. Looking good though and glad to see you got back to work on it.
Old 20th February 2013, 08:29 PM
Hi Chris,
Good to see you're back at it
I look forward to seeing more photos soon.
Old 20th February 2013, 10:21 PM
Cheers guys. I'm pretty sure my plums are safe! :-)
Old 8th March 2013, 05:18 PM
I've been quite busy of late. check out my new flickr photostream. I've decided to make some headway towards starting the engine so unfortunately this means I have to finish some of the jobs I've started.
So I've sorted the cooling system with mostly new pipes but still need to get a plug for the rads original coolant temp sensor hole. Other than that it's just a few jubilee clips and a metal hose support away from testing.
Also made headway towards a usable tank. Managed to rotate the sender unit with a neat little triangular bracket made from some galvanised steel from the garage door. And bent the sender float wire so it sit neatly just above the fuel pump. But when this tank says empty it definitely is empty!! No guesswork involved, ok there will be about a litre in the sump but that's it! I've then cut the metal plates from the top of the mazda's fuel tank, cleaned them all up and used J B Weld to fix and seal them to the top of the tank. I have also used the mx5 breather system as it seemed silly not to, but I don't think I'll be using the carbon can as it's just more plumbing for no real gain other than EU emission regulations I think.
Hope to get the tank attached to the car this weekend and also finish the cooling bits and bobs. Might have to start/finish that gearbox mount I've been putting off because I can't make up my mind what to do, Hmmm!
Old 10th March 2013, 04:49 PM
Hi Chris looking good.
The MX5 breather, does it vent and allow air in when the tank is being emptied??
I was looking to use one of those £30 parts from CBS but if the MX5's works both ways I may use that as I still have my donor.
Old 10th March 2013, 06:19 PM
It must do I guess.
Old 16th March 2013, 09:55 AM
Bit more done! Made a plug for the rad out of an old brass mk2 golf mechanical injector insert, a 22mm copper pipe blank and plumbers lead solder with silicone sealant used to fit it.
Old 16th March 2013, 10:00 AM
Tank is fitted and plumbed in and filter location sorted.
Old 16th March 2013, 12:42 PM
I just got a Golf rad thermal switch which is supposed to go in that hole, it was just about £4 or so. As a bonus I got an extra thermal switch I can use :-)
