Old 4th March 2013, 02:07 PM
Shorty Shorty is offline
Default steering column bearing mounting
A this seems to be a common problem with iva I just wanted to make sure I get it right as I've seen so many different ways of fitting.
Does anyone have any pictures of how they have done it? Especially if you have passed iva.
The bearing I have ordered from ebay is SLFL1 as I read somewhere that the 1" is a better fit than the 25mm without having to machine down the bush.
Looking at it, it seems as though I could bolt straight to the 3mm plate?
Open to any suggestions
Old 4th March 2013, 02:46 PM
loony's Avatar
loony loony is offline
Here's mine:
It's 25mm and I didn't have to machine down the bush - it was already machined for years of use
It's bolted to straight 3mm plate and self-adjusted.
Lucas
My build thread
Old 4th March 2013, 06:29 PM
That's exactly as I was wanting to do it.
Why don't you have the plate covering the full width?
Old 5th March 2013, 08:39 AM
loony's Avatar
I'm not sure if I want it under or over TR8 - it depends on engine/headers position in relation to steering column... and I think it's stiff enough
Lucas
My build thread
Old 5th March 2013, 01:31 PM
Originally Posted by loony View Post
Here's mine:
Did you have to fettle the other half of the clamp to clear the top rail?
Old 5th March 2013, 01:49 PM
loony's Avatar
No - clamp (bearing housing) is untouched - looks tight but there's even about 1mm clearance between clamp and TR8
Lucas
My build thread
Old 5th March 2013, 06:55 PM
Are both parts of the housing on the outside of the mounting plate then?
Old 5th March 2013, 10:13 PM
loony's Avatar
Yes, they are both on the engine side of the plate.
Main hole in plate has about 60mm diameter...
Lucas
My build thread
Old 5th March 2013, 10:26 PM
jps jps is offline
Does the bearing rotate in the mount? Our does it have to be mounted at the angle the column runs at? In the picture it looks as though the bearing is angled relative to the mount it sits in (if that makes sense?!)
Old 5th March 2013, 10:42 PM
loony's Avatar
Bearing rotate in the mount until you tighten nuts - then it's quite solid mounted but at the angle.
I wonder how it will work with adjustable column, but should be ok - it doesn't need too much move...
Lucas
My build thread
