Old 31st March 2013, 01:20 AM
It does Kevin! Good job on yours too.
Old 3rd April 2013, 11:22 PM
Well just come in from the garage after starting the job of chopping up the loom and soldering it all back together again. The chopping happen on Saturday I think or Friday and now the soldering of a much shorter loom with no joint connectors at all has finished, and f*** me it still starts, how surprised was I? I did weld a loose lighting wire to the chassis by accident at first which was a bit scary but yep started first time! Yet to do an led diagnostic on it yet but WOW. Must of spent 40+ hours in the garage over the last 4 days, thanks to the long weekend, lots of late nights and every spare hour out there with 2x 1kw heaters but worth it now. Couldn't sleep last night as I was having paranoid wiring dreams! And I have a cold!!
Old 3rd April 2013, 11:25 PM
Loom just needs shortening and everything positioning.
JUST?? PFFFFT!!!!!!!!
Old 4th April 2013, 08:49 AM
Well done Chris!
You did better than I did - I managed to swap two wires over when I shortened mine, and it took me chuffing ages to figure out why and get it running again!
Old 4th April 2013, 10:08 AM
Cheers John, I couldn't quiet believe it, but it gets better! Been out the garage this morning and put together an led kit using an old immobiliser and no fault codes!! Big grin on my face!! Had to do it 4x as I again couldn't quiet believe it!
Old 4th April 2013, 12:28 PM
Any chance of some photos showing fuse box location and where youre running your cables?
Old 4th April 2013, 01:19 PM
Here you are stot.
Wire for rad and maf run down the engine with the other engine wires.
All engine wires come together at the back of the engine before a few of them go to the main engine earth point and the fuse/relay box.
The rest of the wires, of which there are a lot, go down the side of the gearbox before coming up behind the imaginary dash.
They then go to the instrument cluster, ECU, Ignition module, condenser thingy, diagnostic port, fuel pump relay, ignition barrel and, for now, eval valve thingy. They then go off to the back of the car for the tank and battery although I may move the battery to the engine compartment if I can. The loose wires are for the lighting system and will get waterproof connectors when they arrive.
Old 4th April 2013, 01:28 PM
Keeping all the wires for the engine etc to the center of the car, for me, was the simplest and easiest solution, I've removed every single jointing connection and every wire joint is soldered and heatshrinked, works great and was very cheap to do but if I do get a fault I would't want to be the one to try and find the fault. Some of the locations may change a small amount but not much. All the wiring pipes are from the MX5 saving more pennies!
Old 4th April 2013, 01:41 PM
Great stuff thanks!
Old 4th April 2013, 09:43 PM
Well done Chris...
It seems nearly everybody is working on something electrical just lately and accomplishing a major mile stone with their build.
Glad to hear you your car is running fine and I bet you are well chuffed....
