Old 26th April 2013, 08:57 AM
jps jps is offline
Default Pinto exhaust manifold - MK Indy parts suitable?
I've spotted a Pinto exhaust manifold for sale - but from a MK Indy. Any ideas if it'd be suitable for a Haynes with Pinto fitted? Or is it a case of 'it'll be different for each build' - and i'll definitely need one custom made?
Old 26th April 2013, 10:36 AM
If it is not a direct fit it would be a good starting point to either cut and shut it or just rob it of parts to make your own.
Old 26th April 2013, 11:39 AM
carlknight1982's Avatar
I have a wide fit gbs pinto manifold on mine that just had to be tweaked to fit
Roadster No 2 build
Cost to Date : £93
Old 26th April 2013, 02:25 PM
I got a cheap ebay Pinto exhaust for my car for £19. I made it fit. Taking into account that the pinto exits on the drivers side and my engine exits on the passenger side. Just chopped it up and tigged it back together.
Built/IVA'd Roadster - RS2000 16v, ZX6R, Megajolt
Old 26th April 2013, 05:27 PM
ask gbs/kitspares for a zero gt(wide body) manifold without the flange welded.
im useing a zetec but its long enough to get over the top rails i just offerd it up where i wanted it to be and tacked it.
worth aso getting one with a lambda boss for dyno or fuel injection use
Old 26th April 2013, 06:38 PM
I would very much expect a pinto exhaust from an MK will fit a Haynes because the cars are so very similar (both chassis designed by Martin Keenan). i have a pinto in my MK Iny if you need any measurements or photos
Old 29th April 2013, 11:02 PM
mgglep's Avatar
mgglep mgglep is offline
I used an mk exhaust manifold fits well but the angle is slightly wrong I had to cut and move it very slightly depends how closely you want to follow the lines
My Build pics
Old 30th April 2013, 10:59 AM
my gbs/kitspares manifold
Old 6th May 2013, 11:44 AM
just a thort did ashg not use a pinto manifold from a kitcar and have to extend it a bit to make it fit?
i can tell you tiger ones dont suit
