Old 19th May 2013, 11:49 AM
Ah ha, I think I may have fixed the idle surge problem (or at least covered it up!)
There's a hidden adjustment screw on the air flow meter (you have to drill out a metal plug to get to it).
Wound it all the way in (about a turn and a half), then out 4 turns and the surging has gone
The air flow meter is a crappy ancient vane flow type and I think the screw adjusts the amount of air that's allowed to bypass it when the vane/flap is closed.
My suspicion is that is wasn't allowing quite enough air through at idle and the surging was something to do with the vane opening and closing. I guess it could be a bit sticky at it's closed point, or possibly upset by me not putting it in the correct orientation.
Whatever the case my bodge will do for now
Old 20th May 2013, 01:33 PM
I've gone and blooming done it - just sent off my IVA application
Need to pull my finger out and get it finished now!!!
Old 20th May 2013, 02:26 PM
Well done John......hope I am not far behind you
Old 21st May 2013, 09:43 PM
Well done John! Hopefully I'll be ready for the IVA this time next year!
Old 21st May 2013, 09:54 PM
Just looking through your photos John, are use using those lock stops now?
clicky
Good find!
Old 21st May 2013, 10:30 PM
Sadly they weren't quite a good a find as I'd hoped
The passenger side works well, but it restricts the steering a bit too much on the drivers side...
Old 21st May 2013, 11:44 PM
Oh, bummer.
Old 22nd May 2013, 02:04 PM
VOSA just phoned to relieve me of my bank balance!
They recon it'll take two weeks to process the application and get back to me with a test date.
Old 25th May 2013, 12:36 PM
Not much to report, but here's a few pics I took of her out in the daylight this morning:
Old 26th May 2013, 11:19 AM
Build is looking good. Lets hope you fly through the IVA and we'll have another on the road.
Built/IVA'd Roadster - RS2000 16v, ZX6R, Megajolt
