Old 18th May 2013, 05:54 PM
And then I made up the engine mounts. Had the plates cnc cut to my design.
So its rolling with engine for now. Mount the radiator and gearbox mount and I think im ready to strip it and paint or powder coat the chassis.
Old 18th May 2013, 08:45 PM
Hi Stot,
Making some serious progress there.....
Just a couple of observations though, I see you haven't fitted your diagonals either side of the engine yet.
Also where your bracket for the nose of the diff mounts to the diff plate you may eventually get a fracture in the plate as there is no support there.
Just a thought..
Old 18th May 2013, 09:59 PM
Hi Johno,
You're right I left D1 and 2 til after the engine was in. I also need to do the headlight brackets before I paint it.
Just a thought..
I could put a diagonal back to D12 if it was under that much stress but I'm not sure it would be. Ill take another look at it. its only clamped on at the moment.
Old 19th May 2013, 08:34 AM
Here my first attempt at colour infill. I filled with coloured gelcoat up the edges.
Its really thick so hasn't really settled in the recesses. I'm going to try and overfill and sand down on the next ones.
Brilliant . Stot why dont you use one of phils diff boxes. This mx5 diff mounting saga is making me nervous.
Old 19th May 2013, 09:30 AM
Cheers.
Phils diff box is to fit a sierra frame. It seems the better solution but too late now.
This is the picture Phil did I was thinking of. Mimics the PPF.
Old 21st May 2013, 10:41 PM
Numplumb Numplumb is offline
Default Short nose crank
Hi Stot build looking great and coming along at breakneck speed,I notice that you have a four slot pulley on your crank have you read about these early short nose crank engines havering problems with the woodruff key? also when you say that you want to solid mount your diff like it is in the mx5 I don't think it's solid mounted to the chassis in the mx5 because the ppf is bolted to the gearbox not direct to the body, what do you think?.
Regards Mick.
Old 22nd May 2013, 12:26 AM
PorkChop PorkChop is offline
The moment of the engine and gearbox (from my research, the engine and box weigh approx 175kg) would go a long way to stopping the diff rotating about the driveshaft axis.
Old 22nd May 2013, 10:13 AM
I suppose the PPF did have some twist to it but I dont think it would be a as much as a rubber mount could allow.
The Sierra diff is solid mounted and has worked in plenty of locosts/roadsters, perhaps its a better idea to solid mount the MX5 diff all round. Replace the rubbers with some metal bushes and bolt the whole thing in solid.
Old 22nd May 2013, 07:27 PM
This is what Roadrunner Racing do with their SR2.
Old 22nd May 2013, 08:13 PM
I can easily turn up some bushes so it may be the be the best solution.
I got my floorpan cut out today. I cut it square and clamped it up to my chassis, drew round it and cut it out with some air shears.
Turned out nicely, another part ready to be fitted when the painting is done.
