Old 11th June 2013, 07:00 PM
Yes that makes sense.
Thanks
Old 13th June 2013, 06:43 PM
PorkChop PorkChop is offline
Originally Posted by Johno View Post
Well I've been researching a bit on the net and think I'll be going with option 1.
This should keep the loading on the Rose joints to a minimum.
I guess only time and miles will tell...
Option 1 would be more preferable to option 2. The rod ends would have more bending force acting on them (from acceleration/deceleration) if they were outboard.
One of the best ways though, would be to have an alignment bolt system, like Mazda fitted as OE to the MX-5.
Old 13th June 2013, 06:47 PM
Don't give him any more ideas, he'll never get them finished
Old 13th June 2013, 08:06 PM
Lightbulb
Johno,
Why don't you design an in-board suspension system, where the shockers are hidden away in the bodywork ? I know space is limited, but by Christ, you would have some thing that looks really sweet. The only haynes with in board suspension. I would love to do it, but I have not got the expertise to see the plan through. Another idea I have, is to run the brake lines and wiring inside the wishbones. They are hollow, so why not ? Of course you have to think about strength, but you can't build a kick ass car without taking a few brave decisions. I am doing the wishbone idea myself.
Old 13th June 2013, 08:28 PM
Originally Posted by jason 82 View Post
Johno,
It wouldn't be the first inboard Roadster. 3GE built one inboard chassis (and it's on the road - it belongs to someone on here and it goes really nicely ).
And you would be silly to run fluid lines through hidden components. You have no way of seeing if there is an issue with the lines e.g. corrosion. You could have a real problem with the brake lines chafing with suspension travel, they wouldn't be adequately supported running though the wishbone. Plus, the most you'd be able to hide away is about 6" of line - hardly worth the effort IMO. It may also be against C&R/IVA.
Old 13th June 2013, 08:39 PM
Oh bugger. Scrap the wishbone idea. Suppose there is only ever so much you can do with a 7. Gutted about the inboard suspension, that's what you get for trying to be clever !
Old 13th June 2013, 08:43 PM
Hi all,
Skov's right, no more ideas please I'm now on Mk5 I think.....
Well I'm glad you agree with option 1 Dave because their nearly finished...lol.
The only thing I'm not sure about is do they need a support between the tubes where they weld to the upright bracket/shock absorber mount if you see what I mean.
On my CAD drawing I have a piece of box between them but I'm not sure if it's needed?
Hi Jason at some point I did think about inboard suspension but I don't know enough about it....
Yeah would be nice having the pipes down the tube would it be OK for the IVA?
So what setup you thinking of making?
Old 13th June 2013, 08:46 PM
It's a simple car. Keep it simple. By unnecessarily complicating things, you're introducing potential unnecessary failure modes.
The inboard suspension is a nice idea and it can work; it's been done plenty of times before. It is extra design and fab work, the question is would you gain enough to make it worthwhile? As far as I know, 3GE built that 1 chassis and no more. I don't know why, there has to be a reason (and I'm not saying because it didn't work, I genuinely do not know why they didn't pursue it further).
Old 13th June 2013, 09:12 PM
Hi all,
(IMO) short answer - I personally would if your CAD is accurate to the real thing.
(IMO) long answer - I suppose it would depend on the design of the upright and the length of the wishbone as well as the damper length you're running (and probably more besides) as you would need to determine the position of the lower damper mounting relative to the upright upper mounting. That area is going to have high load through it. If you are still near the SSC/NTS design in terms of geometry, or if it's similar to your CAD image, I would say it would be worth putting a support plate in, as per the original SSC/NTS design.
Old 15th June 2013, 06:50 PM
Well I've finished my latest design of rear wishbone, Mk5 I believe...
That's it, no more changes or tweaks its done...
Hi Dave,
I kept to the CAD drawing and fitted a piece of 25mm SHS between the tubes and fully welded it to the upright bracket support.
The design keeps the shock length the same as the Saturn spec which is convenient as I purchased some shocks this week to that specification.
I feel a lot happier now with this design as it's a lot stronger than the one I had on the car and is still adjustable. I've upgraded the tube size from 19mm to 25mm to accommodate the weld in Rose joint threaded adapters.
So these are now ready for powder coating.
I also got round to bonding my big head fasteners to my bonnet scoop today ready for drilling my bonnet tomorrow and test fitting... Sorry no photo yet.
Still haven't plucked up the courage yet to start the engine...
I was planning to have my exhaust by now ready for the first turn but not quite gone to plan.....LOL
