			#21
			 I'm "currently" haha using them to reverse the rust to some parts! Works a treat for the patient builder!
			#22
			 brillent just found this with only 4 days to iva!
	looks like im ringing iva man to doubble check before i panic ![]()  |
			#23
 That section is particularly badly worded (even by IVA manual standards!), so hopefully it is all a fuss over nothing. Let us know know what IVA man says.  |
			#24
			 spoke to my local iva tester today over phone and he confirmed what i was thinking
	if your fog only works with dip and main or front fogs there is nothing to worry about if your fog works with side only you need to worry about the notes with buzzer etc. its more for mass produced cars that dont meet the std fog only on with dip/main or f/fogs.  |
			#25
			 Panic over
			#26
			 On the foglight subject,I tested a ford ka the other day and interestingly the fog light goes out and will not light again if you turn the lights off,the switch must be pressed again with the lights on to make it work,may be a way out aof problems if someone can explain how its wired up.
	Cost : Little as possible. Thanks : To those who by their generosity my build has progressed. Its a handmade sports car not a flaming kit car !!! If at first you dont succeed,avoid skydiving... No parachute require to freefall,only if you want to do it twice.  |
			#27
			 Spoke to the IVA tester, and the bloke that seems to supervise them, about this at my test today.
	They admitted that it's poorly worded and said it should be changed in the next version of the manual. Essentially we don't need to worry about it. Like Baz says, it only applies if the fog can stay on with side lights (which it shouldn't really!).  |
			#28
			 Just tested mine.....sierra donor loom and my fog light stays on with side lights too
			#29
 feed this to the coil of a relay then take a fused ign feed to the other side of the relay coil then use the contacts of this new relay to break the feed to your fog light switch this way you will only have the fog light working with sides,ign and headlight dip or main ![]()  |
			#30
			 Probably me being a bit thick but what type of relay do I use? Bit at a loss as far as electricery goes!
