Old 22nd June 2013, 10:03 AM
Default cheap rear wishbones?
I'm about to start a production run of book spec (sierra) rear wishbones top and bottom with adjusters, would any body be interested in a set for £115 delivered?
Old 22nd June 2013, 06:05 PM
SteveMX5 SteveMX5 is offline
Not helpful at the moment but if you do the same with MX5 ones I will have a set
Old 22nd June 2013, 07:47 PM
PorkChop PorkChop is offline
That's a very good price Phil
Old 22nd June 2013, 10:30 PM
sparkybagnall sparkybagnall is offline
i no things are a bit akward at the minute phill but did you get any further with your roll cage plan as i was impressed with the design
Old 23rd June 2013, 06:13 PM
thats a fair engough comment phil any ideas how much it would cost
Old 23rd June 2013, 07:15 PM
I am indeed, you have a PM
Old 25th June 2013, 08:10 AM
Nismo1982 Nismo1982 is offline
At the end of next month I will no longer be supplying the Saturn designed wishbones.
Hi Phil - may I ask why you intend to stop producing these? Do you have your own design to suit MX-5 or is it just lack of demand? I would have been after a full set once my chassis is ready
Mark
Old 25th June 2013, 02:42 PM
Makes perfect sense to streamline your product offerings, Phil.
Also sounds very interesting given I am only just starting on the top rails at the moment. My intention was to go per the Saturn plans which as yet have not moved away from book spec.
I know you are busy but I would be interested to know the timescales you have in mind for completing your plans? This might make me change direction slightly.
I presume your plans will utilise your custom diff case to get around the old mounting issue too??
Mark
Old 5th July 2013, 09:39 PM
Numplumb Numplumb is offline
Hi Phil I would be interested in some MX5 wishbones for that price, and would you do your new bent front ones for the same price?.
Regards Mick.
