Old 14th July 2013, 11:41 PM
thailoz thailoz is offline
Default rear axle width
Ok I have tried to find this in search but not a clear answer.
As some of you may know I am having great difficulty in finding a donor,
what I need to know is what is the total width from hub face (wheel mounting face ) to hub face of the sierra rear.
I may have to go live axle
but we will see
Old 16th July 2013, 01:00 PM
snapper snapper is offline
Just found this
Ford Sierra 2.0i is a sedan/saloon with 5 doors, 5 seats and rear wheel drive (RWD). This model has been released in 1989. The automobile is 1372.00 mm high, 4424.00 mm long and 1695.00 mm wide. Moreover, this model's wheelbase is 2608.00 mm, its front and rear track are 1451.00 mm and 1468.00 mm respectively.
Just measured my car and its 1400 between the lip of the drum backplate so 1468 is about right
Old 16th July 2013, 02:32 PM
The track is measured between centrelines of tyres. So, the width between the wheel mounting faces (including the thickness of the drum, mind) should be 1468 + 2 * 35 (the wheel offset), so 1538 in total.
Old 17th July 2013, 05:53 AM
Wheel offset ET for Sierra was 38 and is a minus figure i.e. the amount the wheel centre line goes in towards the body relative to the wheel mounting face
Lets not confuse matters
As I said earlier in my post I have measured to the drum back plate at 1.4 meters, data quotes 1.468 and unless you have measured it that's what it is
Old 17th July 2013, 11:41 AM
Well, I don't have the roadster at hand to measure the geometry, and mine is buggered now anyway, but I have 2 spare brake drums. Their thickness from the backing plate flage to the wheel seat is 65-70 mm. So, if we combine your measurements and mine, ~1400 + 2 * 68 = ~1536.
And you're mistaken about the wheel offset. Sierra's offset is positive and positive means to the outside.
Old 18th July 2013, 06:54 AM
No I am correct on offset
Look at car wheel bible
ET without a - is in
With - is out compared with wheel centre line
I.e. ET 35 means your inner wheel face is closer to the car
Escort run ET from 22 to 15 a d have a deeper dish
I run ET 23 on one set of wheels and they stick out further than ET35
A lot of deep dish Escort wheels are 0 ET you can see the difference
The "ET45" figure below that though symbolises that these wheels have a positive offset of 45mm
In other words, they have an inset of 45mm.
Read more: http://www.carbibles.com/tyre_bible_...#ixzz2ZNDNL5Vx
I can explain it to you but can't understand it for you
Old 18th July 2013, 01:01 PM
You're both right guys
Snapper is right about the ET, positive ET makes the weels go "inside" the car.
But Alga is right to add 2x the ET to the track to calculate the distance between the two wheel mounting faces ad Thaioz asked.
The track is the distance between the 2 centrelines of the wheels as Alga says, and with a positive ET, the centrelines are more "inside" the car than the wheel mounting faces.
So the distance between the two wheel mounting faces, it is definitely the distance between the 2 centrelines of the wheels (track)+ the 2x the ET of the wheels the track has been measured with.
Hope I'm not adding more confusing to this thread
Old 18th July 2013, 11:25 PM
All of that is completely obvious to me. But we were discussing the distance between the wheel mounting faces. Positive offset means the mounting faces are further apart than the wheel centrelines. You said:
Which is just wrong in this context.
