#691
John's right, it's a lot more orange in real life...
Well it's been sandblasted then at least two coats of etch primer and a couple of coats of polyurethane so should last a while. Not good news about your prop John.. I got mine shortened at Dunnings and Fairbank which in the end wasn't a bad price I guess at £69 shortened, balanced, painted and delivered. ![]()
Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction. Albert Einstein http://s1199.photobucket.com/albums/aa472/JohnoSS1/ Johno |
#692
Got hold of Northwest Propshafts, they were a bit surprised saying they had never seen that problem before.
They're sending a courier to pick it up and will see if they can rework it to make it fit. The front diff mount's taking me a bit longer to fabricate than I had planned anyway, so hopefully the propshaft issue won't set me back too much if at all. |
#693
I have spent some time trying to adjust my handbrake cables so they clear the rear bulkhead. I think I have made them even worse.
I have shortened the bracket and pulled the cable up attaching it to the diff hangers. Skov / stot? - how much have you chopped out of the bracket? Any ideas of how I can increase the clearance....... I am starting to loose the will to build my car. Once this is done I will commit to paying for bodywork and the last few bits. David
#694
I chopped about half an inch out of the brackets, and bolted the cables to the diff bracket things and that was (just!) enough to pull the cables away from the chassis. I also raised my rear ride height slightly for the re-test to give me that little extra clearance ![]() |
#695
I know that feeling, I'm approaching hibernation once again.
#696
I am selling an engine and tidying the garage, which means there will be another small push soon....
#697
I've been out in the garage again....
I now only have one knuckle with skin left in it but my rear cables are now well clear of the rear chassis. I will post a photo in my build Thanks for the inspiration to keep going!!!!! David
#698
The slight change of angle helped more than how much I took of to be honest. I will likely take them off again and fill that hole with weld and grind it so that it butts up all the way along as it could swivel a bit if the bolt came loose. Cheers Stot
1.6 Mazda B6 : Garrett TBO339 : 420cc WRX Injectors : FMIC : Microsquirt V3 : LC-2 Wideband : Toyota COP : 1.8 ATB LSD Build Started Jan 2013 : OTR Aug 2014 : Still OTR June 2024 |
#699
Finally got my propshaft back yesterday. It fits this time which is nice
![]() Just bolted it all up with my new front diff mount and Stot's solid diff arm mounts. Here's some pictures for what it's worth: I'll report back when it breaks (assuming broken wishbones or the awful handling doesn't put me in a ditch first). |
#700
Great, lets us all know if it feels any different.
