Old 30th August 2013, 09:23 PM
I made a windscreen surround tonight.
Came out nice.
Old 31st August 2013, 10:22 AM
Moar info please! What size of channel did you use, how did you choose the height of the glass? And how did you bend the channel so cleanly?
Old 31st August 2013, 06:59 PM
Well it just so happens that I was making a fly screen version and took some photos.
I got the channel from a localish company that make the Caterham and Ariel Atom cars but they don't deliver so I had to pick it up. Really hard stuff to find but I'm sure aluminum extrusion stockists can probably get hold of it. Looks like this, has a 9mm channel and the bottom section has a channel for a seal strip.
I made a form from 9mm MDF, put the channel on the top edge, clampped some steel plate with packers around the frame and held it in a vice while I slowly bent it round.
Old 31st August 2013, 07:06 PM
If you are slow and sure the bend comes out perfect but one on this one didnt however you can panel beat the annealed channel and file/sand it flat if it does wrinkle slightly as shown in the pics below.
Before:
After:
For the height I used trial and error. I basically had someone hold the MDF in place and sat in the drivers seat and took the view that the top rail being in line with the upstairs windows of the houses opposite me, ~20m away, worked well which was 13" as it turned out. My fly screen is 4" and when sat in the drivers seat I can still see the nose of the car above it.
Old 31st August 2013, 07:09 PM
Today I also finished my steering column extension. As well as welding it I cross drilled it and pressed in 4 roll pins.
I welded the roll pins in also. Its not going anywhere.
Old 31st August 2013, 08:04 PM
Is there a requirement for a screen surround/channel? I have just bought a piece of 6mm polycarbonate and I intend to fix it at sides and bottom leaving the top edge clear.
Old 31st August 2013, 08:10 PM
As long as you can radius it to requirements it should be fine. J15s have an open top on their screen thingys and people have passed with those.
Old 31st August 2013, 08:55 PM
Thats OK --I am no longer interested in radii
Old 31st August 2013, 10:06 PM
That's a good point.
Old 1st September 2013, 04:27 PM
Another productive day. I got my exhaust downpipe all tacked together.
Got my brake and clutch pedals in place properly whch included turnong up new push rods for them.
