Old 9th January 2009, 09:36 AM
gus's Avatar
gus gus is offline
Question Engine Age
If you are using the engine from the donor vehicle do you still need to get a proof of age letter from the original engine manufacture.
Surely if the engine number matches that of the one on the V5 for the donor then that is good enough for age purposes.
Thanks
Gus
Old 9th January 2009, 09:55 AM
Possibly no to V5 verification as the engine may have been changed since manufacture.
Probably just down to the jobsworth at the DVLA. With some it'll be ok & others it won't.
I should have no problem if I go the Pinto Route. The donor Transits Vin number includes the engine number.
I'm sure you will get the right advice on here though.
Old 9th January 2009, 12:10 PM
If you have a look at this website:
http://www.burtonpower.com/technical...ate_chart.aspx
It gives you the date of manufacture for the engine from engine number and VIN number. Hopefully that and the V5 should be acceptable, mine is NB which is January 1992. I've sent a letter of to Ford asking them to confirm engine age but i don't have much faith in getting a response.
Old 9th January 2009, 12:49 PM
Thumbs up Top link
Top link that one.
It would appear that Ford have allways included the engine number as the last 7 digits of the VIN .
Easy to check the V5 to see if the original engine is still fitted. Even DVLA can't argue with that one or can they !!??
That will explain why my 1987 Transit has the engine number as part of the VIN.
Old 10th January 2009, 10:39 AM
les g les g is offline
Default engin age from ford
Here you go guys
if you need written proof of your ford engines age
write to this address with your engine no. etc and just ask for proof/verification of age of engine
there is a fax no as well but i,ve lost that for the moment
FORD TECHNICAL INFORMATION DEPT
PO BOX 300
WALSALL
WS5 4QH
cheers les g
Old 10th January 2009, 01:31 PM
Nice one Les
Old 10th January 2009, 08:33 PM
snapper snapper is offline
I colour photo copied the age page from the Burton catalogue and that was accepted by SVA man
