Old 2nd September 2013, 10:52 AM
Default VIN Plate
Does anyone know what weights I should put on the identification plate?
I know when skov did his he only had to show manufacturer and the VIN no but i have read the new IVA manual and it looks like the lot has to be added again?
Can anyone confirm whether this is the case and also what weights I should put in if required.
Old 2nd September 2013, 11:09 AM
Hi Dave ...see note 2 on statutory plates ....it states they do not have to be present but if are should be in order shown in required standard note 6 so don't bother (i'm not)
Old 2nd September 2013, 01:09 PM
Are you just going with the vin stamped/welded into the chasis?
Old 2nd September 2013, 06:09 PM
yes that as well but you still need a vin"plate" pop riveted on say the engine bulkhead or easy to see place.... something like this
MANUFACTURER D BOLAM ENGINEERING
MODEL HAYNES ROADSTER
VIN SABT*************
Old 2nd September 2013, 08:13 PM
The only mandatory information is manufacturer and VIN number. If you put anything else on there you're asking for trouble!
This is what I did and the tester was perfectly happy with it:
Old 2nd September 2013, 10:12 PM
Heres mine.
Old 13th September 2013, 09:14 PM
I've been reading the manual again and it says you cannot use the letter O however the vin I was given from the dvla office has both letter o's and number 0's. has anyone else cam across this?
Old 13th September 2013, 09:25 PM
They all start SABTVR0 from the DVLA. They say it 'Vee Arr Oh' but it will be entered as a Zero.
Old 13th September 2013, 09:50 PM
It's been typed on the letter as Os and 0s so will just make them all zeros
