Old 10th September 2013, 04:25 PM
StruveD's Avatar
StruveD StruveD is offline
Default DaveStruve Build Log
Completed Car:
Build Log:
Kind of getting a late start to this build thread, so I'm going to back date it a bit to show whats been done.
Project Outline:
Start Date: May 7, 2013
Build Plan: Haynes Roadster with Saturn Modifications
Donor: Mazda MX5/Miata (on this side of the pond)
Slideshow: http://s125.photobucket.com/user/xcr...show/Lotus%207
Engine: Cleaned up, painted and supercharged 1.6
Seats: Lotus Exige
Rear End:
Torsen Limited Slip Diff
Old 10th September 2013, 04:30 PM
StruveD's Avatar
Ok and now on to where we are at today. As of yesterday I had a rolling chassis. Ride height is a inch to high at 6.5"/165mm. I'm debating whether I should lower it.
Old 10th September 2013, 04:53 PM
lookin swell there Dave and love the rims....engine looks mint
that's going to be an interesting fitting job on that power plant..
Welcome
Old 10th September 2013, 04:55 PM
StruveD's Avatar
Welcome
Biggest concern is clearing the supercharger. But I'll either make a custom hood, or fabricate a new bracket for the supercharger so that it sits a bit lower.
Old 10th September 2013, 06:26 PM
Dualist's Avatar
Dualist Dualist is offline
Quality stuff so far mate, love the seats and the engine
Old 10th September 2013, 07:45 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
Looks very nice indeed
Was about to say about the steering column being on the wrong side but its been said to death and its only the japanese and australians that listen
All seriousness very good work in such a short space of time look forward to seeing your progress
Old 10th September 2013, 09:02 PM
The ride height will change when you swap those box section shocks for some thing with a little more give to them. The lower wishbone bolts and the ball joint bolt should be more or less horizontal to each other the bend in the lower wishbones is to clear the rack arms.
Old 10th September 2013, 09:09 PM
StruveD's Avatar
I was just looking at that, so I should base it off the bolts being horizontal and not the wishbones? It threw me off a bit because the 2 plates that clamp the upright are even with the bottom of the frame.
Old 10th September 2013, 09:22 PM
Looks absolutely stunning there matey..
Very envious of your engine setup but the only problem I can see is it's not mine....
Cracking build throughout so far, so please keep the photos coming.
