Old 29th October 2013, 09:55 PM
Nismo1982 Nismo1982 is offline
Phil
Is the book spec separation of sb4 enough to allow for the offset of the mx5 diff?
As I have now placed my order for one of your diff covers I'm looking to crack on with the rear suspension framework and originally had the sb rails setup per Saturn design. About to revert back to book spec rear end now but just want to make sure I don't have to rework anything else.
Mark
Old 29th October 2013, 10:56 PM
Smile
Originally Posted by Nismo1982 View Post
Phil
Mark
Your doing the same as me! After talking to Phil about this it's book spec rear end but sb4's have to be spread out I have set mine to the Saturn design distance just the sb4s to allow the clearence needed but u do have to move the tunnel rails to line up with the sb4s.
Build pictures
Old 30th October 2013, 07:35 AM
SB4 on the drivers side needs moving by 5mm but you also need to take the input flange into account and the prop shaft, I'll send you a proper set of drawings and pictures once I have got both the 1600 and 1800 in place.
Old 30th October 2013, 09:14 AM
Great, thanks. I will leave my SB's tacked in place just now then and get the rear frame done.
J.brownster: good to see someone else going down the 'new' route. Seen ur name on the wishbone list too which is also what I'm doing. Should save a fair bit of time!
I'm off work this week so getting rear end done today then start stripping the donor next couple of days...good times!
Old 30th October 2013, 09:40 AM
Smile
Yea my name is on there but awaiting for Phil to send an invoice for me to pay him some money so there all ordered plus the diff cover but I think he must be a busy boy at the moment!
Build pictures
Old 9th November 2013, 10:00 PM
Justin, the invoice was sent to you on the 30th October please check your emails/spam.
All the components for all the TMXR wishbones that are on order have been cut and profiled ready for assembly.
Old 8th December 2013, 08:26 PM
sparkybagnall sparkybagnall is offline
just like to say thanks to phil i received my engine mounts as promised and there excellent very happy customer
any news on your roll cage yet
im lucky enough to be off to jan the 6th now and really hoping to make some progress on the car this month
Old 2nd March 2014, 02:22 PM
xsnoiz xsnoiz is offline
Phil, what would be the damage for a set of plans? I'm in West Oz, so a chassis premade isn't an option for me.
