Old 29th October 2013, 04:06 PM
They need to cover the wheel dia. not the tyre They look OK to me.
However if you feel you need cycle wings I have a spare pair( no metalwork as yet though)you can use-- in black.
Old 30th October 2013, 11:03 PM
Numplumb Numplumb is offline
Rally Design have kindly agreed to let me send them back and exchange them for some 11" x 8"s with 7" springs.
Hi Stot can i ask you as I'm going to Rally Design were these the right ones in the end?
Also what poundage did you get were they 250? And we're the 14" ones correct for the front, what poundage did you get for them?
Regards Mick.
Old 31st October 2013, 09:04 AM
Hi Mick,
I ordered these standard GAZ shocks from Rally Design and they fit nicely. About 1/2" little less droop at the rear than the custom extended ones NTS/Saturn supplied which didnt concern me as these are a cheaper off the shelf option.
Front = 14" open, 9.5" closed - 140/095/B12
Rear = 11" open, 8" closed - 110/80/B12
Springs I went for
Front = 350# - 8" - RD1.9/350/8
Rear = 250# - 7" - RD1.9/250/7
Although looking at Skovs latest posts about spring rates he is hardening up the rear somewhat having driven his a while now.
Old 31st October 2013, 04:42 PM
Hi Stot thanks for that information I think I'll go with the same ones then, one other question the front top wishbones have unequal legs am I right in thinking that the longer one goes to the rear as the brackets don't seem to sit squarely on the uprights either way round but seems better with the long leg at the rear.
Regards Mick.
Old 31st October 2013, 06:45 PM
Regards Mick.
Actually the long one goes to the front so that the TRE is set back from center. Figure 25/Page 13 of the current Gillham/Saturn plans shows it quite nicely.
I had it the other way round at first and it caused a ridiculous amount of bump steer until I noticed the problem.
Old 31st October 2013, 09:12 PM
Thanks for that I must have looked at that with my eyes closed should've gone to spec savers LOL.
Old 1st November 2013, 06:54 PM
Hi Stot I went to Equinox today to get some body parts and mentioned to Dave that you wanted to borrow some cycle wings and he said he might be able to help you if you get in touch with him.
Regards Mick.
Old 1st November 2013, 09:06 PM
Regards Mick.
Body parts?----What do you need? A couple of spleens, kidney, lungs?
I have a spare brain--it wont cost you an arm and a leg.
Need some more valves for your head?
My missus has a spare tyre(or two)
Old 3rd November 2013, 12:24 PM
Mrs ayjay isn't reading this then. Don't know if you are brave or loopy
Old 3rd November 2013, 12:40 PM
rpjg1975 rpjg1975 is offline
I thought someone had been taking extra brave pills!
Russ
