Old 21st November 2013, 07:22 PM
rpjg1975 rpjg1975 is offline
I'm probably looking at just getting a set of drl lights and fitting on brackets below the headlamps. Will be sods law that they will decide to make them compulsory later then have to piss about adding wires later in the build. They are next to nothing to buy anyway so might as well do it while in the design stage
Old 21st November 2013, 08:43 PM
davidimurray's Avatar
Keep it as simple as you can for the IVA, just build in any spare cables/hoses/mountings and fit after the test. You will have plenty of time to modify after the iva while waiting for the dvla to register the car
The silencers fitted to gsxr 1000 k4 have a cat inside the silencer so could be an option but you would need to prove it Bob to keep him happy.
Bob was very fair and realistic when he looked at my car, certainly one of the better inspectors - If you haven't seen it have a look at my IVA post. Beware he does heave a bit of a gripe about side repeaters and prefers them on the fron wings. He measured mine very carefully.
Old 22nd November 2013, 08:22 AM
Fit two LED one's behind the grill,would work no probs and should only work without any other lights on,front only.
Old 22nd November 2013, 02:23 PM
Cool, cheers for info guys
