Old 27th November 2013, 11:30 AM
Default Making your own GRP products
Hello,
I am in the process of tying to make my own GRP instrument Binnacle, however I am trying to locate a company that sells Stryofoam for a reasonable price to make the basic shape.
Does anyone know of a supplier near Newcastle / North east that can do this cheaply??
Thanks
Old 27th November 2013, 12:40 PM
You knows what am going to say.....EBAYYYYYYYY
http://www.ebay.co.uk/sch/i.html?_sa...e+block&_frs=1
Old 27th November 2013, 12:45 PM
Carobell Reticell Norham road N/shields
Its possible if you have shape in mind they could cut it for you.
Or ,florist suppliers .
Old 27th November 2013, 01:16 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
You can cut it using nichrome wire and a pp9 battery I use east coast fibreglass for the foam
Old 27th November 2013, 03:17 PM
You need to use expanded polyurethane foam either the blue or pink stuff with polyester glass gel other wise polyester gel will melt polystrene the common white stuff. I use a timber panel saw and a hand rasp to shape the foam it's easy enough just makes a bit of a mess.
Old 27th November 2013, 03:38 PM
vmax1974's Avatar
You need to use expanded polyurethane foam either the blue or pink stuff with polyester glass gel other wise polyester gel will melt polystrene the common white stuff. I use a timber panel saw and a hand rasp to shape the foam it's easy enough just makes a mes.
Isn't the pink and blue stuff extruded thought the white was the expanded
Old 27th November 2013, 03:43 PM
Doesn't matter, EPS and XPS are melted by polyester resin, you need either PU foam, or PS foam coated with something like plaster.
Old 27th November 2013, 07:58 PM
Thanks for the replies. I spoke to ec fibreglass. They sell the pu foam fairly cheaply. I would normally use ebay but I'm never in to collect the parcels.
Old 27th November 2013, 09:35 PM
vmax1974's Avatar
Glad to have been any use at all ec fibreglass are quite handy as the are fairly local so its easy to go and collect what you want and they are fairly knowledgeable and free flowing with the advice
