Old 21st December 2013, 11:03 PM
Richard Dryden Richard Dryden is offline
Default dimensions
Does anybody now the dimensions of the equinox bodywork, specifically the scuttle, bonnet and nosecone as I'm about ready to order my panels but am a little concerned about clearance over my 1.8cvh and even more so its carb air intake. So I'm wanting to do a few checks first. Many thanks for all your help in advance.
Richard
Just keep going we will get there in the end.
Old 22nd December 2013, 06:56 AM
Ben_Copeland's Avatar
I'll measure up today!
Old 22nd December 2013, 08:32 AM
Default :)
Thats great thanks Ben
Richard
Old 22nd December 2013, 08:56 AM
Hi,
Ben gave me the heights of Equinox's bonnet some time ago, which are what you need for the under-bonnet engine clearance:
264mm back (scuttle side)
203mm front (nose side)
+4mm thickness of GRP side panel on top of TR1/TR2
Hope this can help
Old 22nd December 2013, 09:32 AM
If there's any more measurements you need just let me know.
It's all off the car atm so easy to measure. I think I'll do a diagram shortly so every possible measurement can be put on
The bonnet scoop adds a bit more height for front cam cover etc
Old 22nd December 2013, 10:14 AM
Hi Ben,
Yes, if you could, one of these days, make and publish sketches with all useful dimensions of the different elements, like Saturn did for their body work at a time, it would be very helpful (and I think a good selling help for you and Dave)
I would like to know all the dimensions of the bonnets, with no scoop, small scoop, and the exact location of the scoop, because I need to plan what I will do with the big plenum chamber of the inlet manifold of my Sierra DOHC.
Does Equinox plan to design and produce a large scoop bonnet?
Thank you.
Old 22nd December 2013, 09:12 PM
loony's Avatar
loony loony is offline
Did you think about fitting Kia Carnival scoop on the bonnet (like MK indy) ?
I think it can be useful... and cheap
Lucas
My build thread
Old 23rd December 2013, 07:36 AM
Smile
Hi Ben,
Thank you.
Ok I'll try sort something today for you.
Dave was going to make a large scoop but it got moth balled as he got so busy with bodywork and other projects
Old 23rd December 2013, 09:05 PM
I've done some crude drawings of the nose one and scuttle with measurements on.
It'll do for the moment till I can take photos and mark them up instead.
Old 24th December 2013, 01:19 PM
Thank you Ben, it gives ma good idea... that I can't fit the plenum chamber of my Sierra DOHC under this bonnet which is the tallest of all body kit's bonnets. As it is now, the top point of the plenum chamber sticks out 270mm over the top rails and is located on the rear/right side of the engine bay.
It means that I will have to make a cut on the bonnet and put an air intake/bonnet bulge, or cut and re-weld the pipes of the inlet manifold of my Sierra DOHC.
You're a natural born drawer, no? Just kidding, thanks for the dims !
And let us know if and when a wide scoop bonnet is available.
Thanks.
