Old 9th January 2014, 02:34 PM
Wain Wain is offline
Default Hazard lights
Bit of a tangent to the conversation, but i have purchased the pedal box from CBS, but the accelerator pedal does not offer enough movement to fully extend the throttle cable. I have instead built a new accelerator pedal which now does the job, but is bigger then i wanted it to be, but needs to be this size to allow the throttle cable to fully extend.
Has anyone got any pictures of a similar set-up that works?
One day it will be on the road......
Old 9th January 2014, 03:08 PM
You could make a smaller pulley at the throttle body end and keep the original pedal.
Old 9th January 2014, 03:16 PM
That's a good idea, is that what you did? does it work alright?
Old 9th January 2014, 03:26 PM
I havent done it yet but I will if I dont like the travel. I made my own pedal box and I think the travel is ok.
Old 13th January 2014, 02:18 PM
Well after further investigation i have found that the hazards use a fuse called BTN2 which is in the main fuse block. Underneath this, i do not have anything connected and i have an empty socket, but i cant find any plugs that fit it.
Any suggestions what should be connected to this socket?
Old 13th January 2014, 02:59 PM
I will have a look in my fusebox tonight and see what is in there.
you might need to go on ebay and buy one
Old 13th January 2014, 03:30 PM
Default Hazard Lights
Ye that's what im thinking, i just don't know what loom is meant to be connected to that socket.
