Old 21st January 2014, 06:00 PM
Wgroove Wgroove is offline
Originally Posted by alga View Post
Interesting! Do you have a design for the dashboard yet? The Caterham scuttle is much lower, there's lots more space on the Haynes dashboard.
There isn't a design yet, but will be doing that part of the build in the next couple of weeks. When there is one, we will be posting it up here.
Are the Caterham scuttles that much lower ? I thought they were at about 10" in height at the side of the dashboard. Not a lot of difference with the Haynes scuttle ?
Old 22nd January 2014, 09:58 AM
Well, maybe it's not the scuttle, but the chassis which is lower.
Old 23rd January 2014, 03:43 PM
Could be, I will do an investigation on that
Old 2nd March 2014, 05:24 PM
Steering wheel that i got from a friend. A souvenir from his old Triumph Spitfire.
Old 2nd March 2014, 07:09 PM
Been working on the back of the car.
Old 2nd March 2014, 08:41 PM
well will you look at that ....even your back end is telling you your steering wheel is on the wrong side
nice work bud, keep on pluggin away
Old 15th April 2014, 05:03 PM
The rear is now fully installed. There is a dent in the alu in the right corner, but I don't think you will notice it when driving around.
Also started with making the dash. Maybe I'll make a mould of it first, to make a glass or carbon fibre one.
Old 20th August 2014, 12:23 PM
After almost 5 years of build...
The front arches need to be done, and some other things to, but we managed to get our car ready for a trackday last weekend.
Tis picture is for those who are still building:
DONT GIVE UP !!! ITS AN AMAZING FEELING WHEN YOU DRIVE YOUR HAYNES ROADSTER !!!
Old 20th August 2014, 07:12 PM
Congratulations for the car, it should be such a good feeling to drive it It looks very nice.
And good for you you drove it before doing the front wing stays, at least you had a moment of enjoyment before the hassle. I've been on my front wing stay for 3 days now, and still can't get them right
But hopefully, within one week, I'll have my first drive with a complete car too.
Keep on the good work, fellow left hand driver
Old 21st August 2014, 10:31 PM
Hm, I put mine together without too much bother, 2 or 4 hours on each, done on the first attempt. Hindsight: 3 mm upper strips are too weak the but 5 mm or so should do fine. Also, place them an inch or so above the tyre. I went for ~15 mm and now I cannot mount a tyre slightly larger than the one I measured with. Update: the upper one does all the flapping, but the bottom (rear) one breaks at the weld from torsional loads.
