Old 1st February 2014, 02:02 PM
Default Headlights
I have some really nice headlights from Staffordshire vehicle components.
I have fitted them finger tight and wired them in.
My question is how do I tighten them? I cannot get a socket on due to the wire ans can't use a spanner as the nut is recessed.... Confused.com
Thanks
Old 1st February 2014, 02:11 PM
TSM Locost's Avatar
Box or Tube spanner, removing wires and socket after setting lights to where you want them.
Be Lucky, Mike.
Old 1st February 2014, 03:30 PM
As above or cut a slot with grinder out of socket and put the wires in the slot,or put wires through hole in socket and use molegrips or the like.
Old 1st February 2014, 04:22 PM
Johno and Tatey had a discussion about that, and there are some pictures of the "home made" socket:
http://www.haynes.co.uk/forums/showt...t=2736&page=24
Old 2nd February 2014, 03:07 AM
thailoz thailoz is offline
I may be way of as i am no where near lights etc yet but my thoughts are to fit the bowls first then wire them in.
Old 2nd February 2014, 07:51 AM
My solution, as eluded to in that thread, is to drill a hole in the thread and exit the wires just below the top mount and into my mount tube. the thread then continues down and out of a lower plate at the base of the headlamp mount and that can easily have the nut done up with a spanner ( and the wires are fully hidden ) .
The big advantage is that the lights can be adjusted without disturbing the wiring ( IVA Bonus! ) if the mounting bolt also acts as the adjuster clamp like mine.
Old 2nd February 2014, 11:37 AM
davidimurray's Avatar
Make a little tubular spacer that puts the nut below the bracket.cable gland over the cable/nut for iva.job done and easy to get an open ended spanner on to adjust.
Old 2nd February 2014, 09:51 PM
Here's my special tool:
http://i.imgur.com/sclV2Sn.jpg?1
