Old 15th February 2014, 08:15 PM
Dualist's Avatar
Dualist Dualist is offline
Comin along nicely. Which reminds me, I must get my finger out.
Old 29th March 2014, 12:20 AM
after contemplating for a while and looking at the options for the rear diff on the mx5 I really liked the idea of talons diff cover!! thinking about heat transfer I studied the diff and thought could I bolt it in my lathe and shave 5mm and make a plate to sandwich in between so I gave it a go seems to of worked and you still use the old ali cover so correct oil level and breather are in place
Build pictures
Old 29th March 2014, 07:57 AM
Nice that's pretty much what I was talking about a while ago but my diff is already mounted so didn't bother with it. Ill know what to do if my diff gives up now though!
Old 29th March 2014, 08:03 AM
Dualist's Avatar
Thats a nice version of Phils idea. Do you know if there is enough meat to shave 10mm off instead for a thicker plate.?
Old 29th March 2014, 10:58 AM
10mm should be ok if you look at my build pics there is a pic on there of the cover before i removed the arms and put it on the lathe the lip it started with was 5mm, the reason why i kept it to 5mm as phils plate is 5mm and it took six hours to make a bracket to hold in the lathe and take the 5mm off!!!
Build pictures
Old 29th March 2014, 09:58 PM
Got to apologise Dualist I had a look at the diff cover tonight and 5mm is the limit to shave it down by otherwise you would hit into the driveshaft seals
Build pictures
Old 23rd May 2014, 07:32 AM
Engine mounts made
Steering shaft made
Pedal box made
Half way through the roll bar
Can't wait to get this all powder coated feel like I'm getting somewhere then!!!
Build pictures
