Old 23rd April 2014, 07:58 PM
Default Mirrors
Just looking at buying mirrors and noticed very few are e marked. then looked in the IVA manual.
"7. All mirrors must have an acceptable approval marking or have equivalent characteristics to a mirror approved for use on a vehicle of the same category as follows:
The reflective surface must be encased in a protective housing.
surfaces contactable by a 165mm sphere (interior) or a 100mm
sphere (exterior) must have a radius of curvature of at least 2.5mm – except for fixing holes or recesses less than 12mm wide, which must be blunted"
So mirrors don't need e marking they just need to comply?
Old 23rd April 2014, 08:06 PM
Yep, no e-mark required.
Old 23rd April 2014, 08:10 PM
Tks. That's my lights and mirrors all sorted and ordered then.
Old 30th April 2014, 01:20 PM
check the glass size is big enough.
Old 30th April 2014, 11:39 PM
SeriesLandy's Avatar
If you have the racetech or similar they are physically big enough (for an interior mirror see this post) but I don't 100% know if they meet the fields of view at iva.
That's what I've got on mine.
Last edited by SeriesLandy : 22nd June 2014 at 06:04 PM. Reason: Edited as incorrect facts
Old 1st May 2014, 10:13 AM
When I had my IVA test all the examiner seemed interested in was looking for E markings. Spent ages looking for them on the tyres!!!
When he queried my reflectors as they didn't have E marks, I pointed out that they don't need to have them. The response I got was 'how do I know they have similar characteristics'!!!
So I swapped them for some spares I had which were E marked.
Mirror size was checked so make sure that they are the right size, and convex to aid viewing angles.
Old 22nd June 2014, 06:02 PM
As I previously stated, the racetech mirrors are not iva ok. They are fine for interior (with trim) but don't comply with the second part of point 9 in the manual.
"An exterior mirror must be a minium of 40mm hing and 70mm long and be able to incorporate a measurement parallel to the height of the rectangle at least 70mm in length within the lens."
Somehow I missed this and it was my only fail on the day. The examiner did let me go and buy a pair so it turned out £60 cheaper than a retest but still expensive for a set of mirrors.
