Old 7th May 2014, 06:15 AM
johnl63 johnl63 is offline
Default mx5 wiring bits question
OK so Im plugging away at the wiring and following some good diagrams bit I have found a few things that I am not sure of what they are ......
I know its not in a haynes but I did start one! the chassis is on my shed wall!!
first the rats nest, I have tracked and labeled everything in blue and then marked the keepers in red (things that I can reattach to the motor)
[IMG]http://[/IMG]
but what are these
1, the heavy blue wire coming from the fuse box? its a single spade connection
2,the small yellow connector that is with the coil connections
3,this thing, its a bit of an orphan
Haynes MX5 based New Zealand
Old 7th May 2014, 06:16 AM
and part 2
4, the brown one here, its on the connection that heads to the radiator
and lastly what it looks like in my chevron
Old 7th May 2014, 10:11 AM
Originally Posted by johnl63 View Post
and part 2
The blue wiring is for the heater fan unit. I will have a look at the other later to see if I can match them. There were a lot of spare ones on mine that I cut out. One of the photos has a little block attached. Ive been wondering what this does as ive got the block in my garage and not on the car (si it cannot be that important)
Old 7th May 2014, 07:29 PM
1, the heavy blue wire coming from the fuse box? its a single spade connection.
Attaches to the Heater unit I believe, mine attaches to nothing.
2,the small yellow connector that is with the coil connections.
Pretty sure there is an ECU temp sensor just near the coils that this plugs in to.
Not sure but a readable picture will help identify it?
I think this one is also a temp sensor for the cooling system.
What colours are the cables going to each of the plugs because that will help a lot to identify them?
Old 8th May 2014, 09:24 AM
3 looks better in this pic
and the wires out of it red and yellow
cheers appreciate the help
Old 8th May 2014, 09:54 AM
SeriesLandy's Avatar
The last one is a relay. Other than I don't have a clue.
