Old 30th May 2014, 02:00 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
kev i will dust my goggles off and come up in the next few weeks when the forecast is right
Old 30th May 2014, 02:48 PM
Roadster? Red Missile.........
Old 5th June 2014, 03:53 PM
Just a little tip for anybody who is at the stage of routing pipes/wires down the t/tunnel, it would be a wise decision to add a few extra wires that do nothing but go from end to end of the chassis, I knew I was going to fit water/meth injection at some point but thought it would be an easy retrofit.... WRONG was I If I had put them in when it was easy to do so it would have been a breeze.......SO if you plan to retrofit stuff later on say after IVA don't its a right PITA
Old 6th June 2014, 08:59 PM
got some el cheapo gauges from China and I am pleasantly surprised at how clear they are even in daylight I have just mounted them in a rough pod fashioned from a blown vinyl torque wrench case and mounted so I can see them through the steering wheel, oil temp, boost and oil pressure, my state of tune means these are the most important ones to monitor.....apart from the rev gauge which I seen hitting 8k recently, (stage 2 map does away with the 7.5k rev limiter )
anyway this is what they look like
Old 9th June 2014, 10:54 AM
MikeB MikeB is offline
they look good for cheapies, where did you get them?
Old 9th June 2014, 02:40 PM
here you go Mike
http://www.ebay.co.uk/itm/2-52mm-Boo...em 3ce1dfe80d
they work pretty well too....delivery was a respectable 2 and a bit weeks which ain't to bad from China.
Old 9th June 2014, 02:51 PM
here they are in the car (temp fit)
and is my very technical water/meth tank/clunk filter pick up
Old 10th June 2014, 08:52 AM
they look well tidy Kev
Old 10th June 2014, 10:45 AM
E-Bay or Heath Robinson Ltd .
Old 13th June 2014, 09:24 AM
Default Thank you!
Thanks Kev for the spin in your roadster last night!
Im still grinning from ear to ear.
That is one seriously ballistic car.. I now think i need to strap a turbocharger on my engine now!
