Old 3rd July 2014, 08:30 AM
Eddy Eddy is offline
Default Next up - The dreaded loom
Hi all,
The next thing I need to sort out for my build is the loom.
I don't really want to re-use the old sierra one, but have kept it for the connectors.
I'd heard that Premier Wiring have a good reputation so contacted them - They want £195.
Then I found that Tiger offer a loom for the Avon for £155: http://www.tigerracing.com/zencart/i...ucts _id=1178
Could this be made to work?
I know I'll have to add connectors/terminals myself anyway, so is the premier loom worth the extra cash?
Are there any other good options?
Eddy
Old 3rd July 2014, 01:18 PM
Hi Eddy, I bought mine from these people, I haven't but it does look pretty good quality.
I just want to get some of the split conduit to tidy it up and happy days I hope.
p.s I don't like electrickery
http://www.s-v-c.co.uk/product/the-b...-engined-loom/
Old 3rd July 2014, 04:14 PM
SeriesLandy's Avatar
I used the sierra loom. I started with the original fuse box and removed everything I didn't need. I then moved over to a fuse board from eBay with crimp terminals. When I was putting the loom in the car I shortened as necessay and the. Loom taped it.
It took time but cost about £20 for the fuse boxes and loom tape.
Old 3rd July 2014, 05:15 PM
I got my car going on the MX5 loom stripped, but I have to say I do wish I had spent some money on a Rapid Fit Looms loom. It would be far more elegant than the elephants nose I have behind my dash now.
Old 4th July 2014, 10:59 AM
Thanks for the replies gents.
That SVC one looks good, but at a similar price to the Premier Looms one.
I can see what you're saying about using the donor loom, Steve.
It would probably work and be a pretty cheap solution, but I'm not that confident with electrics and there would be quite a lot to strip out. I've also read quite a few build threads where, like Stot, people have said if they would buy a loom if they were doing it again.
I'm pretty convinced I want to buy a new one, I just really want to know what the best value option would be - If there is nothing a Premier/SVC/Rapid fit loom would get me over the Tiger one, its got to be better value, right?
Old 4th July 2014, 05:50 PM
I would have bought a rapid fit loom the same as stot if I was doing this again but I think the easiest option is to use the existing donor item. All you need to do is shorten and lengthen it where needed.
Old 16th July 2014, 04:55 PM
I agree with that statement.
Old 16th July 2014, 05:37 PM
I think the scary bit is the ECU. Lights and switches are easy enough to wire in but the ECU has a shed load of wires going to it!
I'm going to be megasquirting my car over the coming months so I will probably end up making that as self contained as possible and doing a full re-wire of the lights etc while I'm at it.
Old 10th August 2014, 01:40 PM
i used a rapid fit loom but i would pass on them. its a great loom but has very little info that comes with it and the support form rapidfit is very poor.
i made my own seprate loom for my fuel injection and i find its the easy way to do it
the key is to have an idea what is where and wire it up when the car is almost finished
a good selection of split conduit makes a easy and tidy way of an install
Old 10th August 2014, 07:39 PM
Enoch Enoch is offline
If you still have your build table you could drive a nail or two in at each location where something needs to be wired. Draw in things like headlamps, side lights, indicators etc so you can see how many wires you have to run and where they need to end up. Draw in two fuse boxes - one for permanent live things eg side lights, hazards, imobiliser etc and one for everything that needs to run off a switched supply. You will end up with a group of wires going to the back - left indicator, right indicator, lights, fog light, reverse light, tank sender, fuel pump - these can run as one loom down your tunnel. In the tunnel you will have handbrake and reverse switches, you may also have a wire for an electronic speedo if you are using one.
Take it one wire at a time and it all seems pretty easy. I would tend to have all my engine management relays mounted near the ecu, it makes life easier for testing and debugging at a later date.
You can then do the same trick as you did for all the stuff at the back with the stuff at the front. Run wires for hi beam, low beam, side lights, left and right indicators.
Do similar with all your engine sensors, don't know what your ecu needs but it will most likely have coolant temp, air temp, fan control, cps etc. Draw on your plan where they all are and allow a wire for them. Keep your wires plenty long at the moment, use unique colours for each circuit and keep a note of them. It really is very simple once you get rolling.
There are pin outs for most ecu on t'interweb, there are circuit diagrams showing how to wire up hazard switches - these are still simple but cause more confusion than just about any other item.
Hope that helps, you can do it, there are many people a lot less smart than you that have done it. Just because there are lots of wires does not mean it is complicated, it just means you have to do the same simple things more times to finish the job.
Best and all that,
Enoch
