Old 7th July 2014, 10:52 PM
Well I have finally bitten the bullet and started attaching the body panels. Still can't fully commit as I know I'll have to take them off again for some reason or other so I've decided to use rivnuts wherever possible.
I'm using stainless steel M4 6mm dia. flat head nuts with 12.9 high strength M4 hex head bolts 20mm long. The reason is because a small allen key will be ideal to get into tight areas if ever panels need to come off and you alway have the option of gripping them with a pair of pliers if the hex head rounds out.
I'm using some small washers to spread the load and tight as I am I did buy the memfast.co.uk rivnut tool as I am a big believer that the right tools make a job much more enjoyable and quicker. I can always sell it in the future but I think it's a keeper.
I was struggling to figure out where the chassis rails where before drilling a 4.5mm hole through the fibreglass but then had the bright idea using my pyjamed assistant to shine torchlight through the back of the panel and as it was almost dark this worked brilliantly in getting the holes in the right place.
I then removed the panels and drilled a 6mm hole in the same position for the rivnut. Rivnut tool is great you can hold everything steady while you hand tighten the bolt. Only needed forearm strength for M4 stainless rivnuts to spread enough.
cont......
Old 7th July 2014, 10:53 PM
I'm looking forward to doing the rest as it went so well!
Bad shot.
Old 8th July 2014, 10:26 PM
Done the other side, it's coming together now.
Might get it on the ramps next and do the underneath rivnuts.
Old 8th July 2014, 10:53 PM
Looking good Chris
Old 10th July 2014, 09:28 PM
Arches.......
Old 10th July 2014, 09:33 PM
I used these collapsing rivnuts. Really easy to install hopefully they will hold.
Old 13th July 2014, 10:43 PM
Coming together, now the weather has decided what to do!
Honestly, it looks better in person. It's a bit of shock when you step out the house and look up, not expecting it to be there, or look so red! I can feel the end.....
Old 14th July 2014, 05:10 AM
Hi Chris,
First, I think the car looks very good. Very red indeed, but it is not shocking to me, I really like it You're almost done, congratulations!
I fitted my rear arches this week-end too, and I was wondering: what kind of trim/piping did you use between the arches and the side panels/rear tube? I can see a black lining there on your pictures, and I often saw that on finished cars, but I don't know what it is, and I'd like to put some on my car too to seal this part.
Could you please let me know?
Thanks.
Old 14th July 2014, 08:07 AM
"P" Trim Sylvain.
Old 14th July 2014, 10:02 AM
That is looking very red and very cool
