Old 28th March 2014, 11:05 PM
Great to hear you've found yourself a donor, just reading your blog now.
Old 28th March 2014, 11:33 PM
thailoz thailoz is offline
Yeah been a struggle but at least I can get on with the build albeit a modified haynes roadster.
I have also followed your build and very impressed with your work.
I am pretty sure I will be changing the engine but I have to go with this to get it regesterd here .
Old 30th March 2014, 08:19 PM
Cheers. Your frame looks really food btw.
Old 30th March 2014, 09:23 PM
Thanks Its suprising what a litle paint does
Old 28th May 2014, 12:12 PM
Default Long time no update
well got a good bit done when I was able to get to yhe workshop and also get the parts required check the blg out guys
Old 1st July 2014, 05:15 PM
Just caught up with your build blog Laurence. You have made a nice job of that 4 link rear end, its very much the same sort of set up that went into the early Westfields. I have actually driven one with a solid axle and they still handle well. IRS is not the be all and end all just a nicety.
Old 2nd July 2014, 09:18 AM
If you make the link that steadies the axle a z shape with a pivot in the middle of the diff case it makes them handle nicer.
It alter,s the roll center.
Old 2nd July 2014, 12:09 PM
Thanks for the comments rob
I have seen that set up fly but wanted to keep it simple
Old 29th July 2014, 12:19 AM
Default I have got a lot done since
as the title says I have made cosiderable progress albeit slow check out the blog for an update.
comments will be appriciated.
Old 20th October 2014, 12:56 PM
Default I hit a milestone today smiling like a dog with two tails
Well I am so happy today I finally got a rolling chassis,As some of you who have been following my build I have had to do considerable design changes along the way.
One of which was the front suspension, I am using corolla uprights (cut down mc pherson struts)also using rose joints and toyota hiace drag links.
I have drawn and redrawn the design in Cad even made a cardboard wishbone (see my blog).
anyways my father(ex Lotus F1 mechanic) came to Thailand for a visit in September and we went over my design which he duly gave the thumbs up on he made a wood mock up of my designe and we worked out the geometry.
I got the parts laser cut and bushes made for drag link and rose joints and this week I finally finished welding them up and fitting so now have a rolling chassis.
I have fitted some sq tube as temp shock to get the road height correct. I will be updating the blog later so check it out for more pics.
