Old 2nd November 2014, 07:46 PM
Rosco Rosco is offline
Originally Posted by SeriesLandy View Post
If your going to use mx5 bits you will need a different bearing btw.
For the sierra shaft you will also need part of the original bearing. (It's all in the guide)
For the cables, about 2-3mm slits just enough to get the cable through.
Yeah I'm use using sierra bits, ok cheers
On another note on the pedal box what are the v cuts for on the foreword stops and also the book says you need 8 shock brackets but two are fixed to the uprights
Am I missing something?
Old 2nd November 2014, 07:49 PM
SeriesLandy's Avatar
I've no idea what the cutouts are for. There are better designs for a box on the forum.
Sus brackets, I count 6 too. No idea where 8 comes from.
Old 2nd November 2014, 07:51 PM
Haha ok cheers, thought i was loosing it
Old 2nd November 2014, 07:56 PM
Found the pedal box here
Btw not every thing in the 'book' actually works. Like using the stock engine arms, the steering shaft goes through the top of the rubber mount.
Also I was at your stage 5 years ago so I may be wrong on the suspension brackets but I don't think so.
Old 9th November 2014, 07:32 PM
Got my chassis welded up this week
Sorry about the photo quality
Old 9th November 2014, 07:33 PM
Also I got my hubs back from the blasters so I can get them painted and built up
That's about it for this weekend
Old 18th November 2014, 09:41 PM
Not so much progress as as I would of liked but never the less, I've made all my wishbone jigs and made a start on them but got side tracked with the rear uprights
Added a bit to the jig to help position the tube and side plates
Old 18th November 2014, 09:42 PM
I've rotated the front plate as from what I can work out it should make the handbrake cable on the rear discs fit better,
Does it look right to everyone?
Also I think the 66mm in the drawing below should be 70mm, I've posted a thread here if anyone can help
http://www.haynes.co.uk/forums/showt...9211#post99211
Old 19th November 2014, 07:01 AM
Tatey's Avatar
Tatey Tatey is offline
Rosco, do you know what engine you will be fitting? Most engines won't fit with the diagonal chassis rail in the engine bay on the drivers side so it is usually removed. Also if you are considering fitting a zetec then you may want to modify the rear up-most chassis member in the engine bay as you can't fit a standard thermostat housing with the chassis member there. You can buy aftermarket thermostat housings but they are stupidly expensive and don't work very well.
