Old 7th September 2014, 11:57 AM
I used an old winch attached to a 2x6" beam in the garage and tied and gaffer taped a steal rope to the two lifting points on the engine. I just slide the rope one way or the other to adjust the position. A load leveller would of helped but I was being tight at the time.
I weighed the engine and gearbox on bathroom scales before putting it in. The Mazda 1.6 engine and gearbox with shortened loom, ecu, manifolds and oil but not gear oil weighed 177.7kg.
Old 7th September 2014, 12:08 PM
JasonL JasonL is offline
Thanks. Where's a good place to get the chain? I've found that it's not much cheaper than a leveller, but I'm sure I'm not looking in the right places!
Old 7th September 2014, 01:21 PM
I happened to have chain for lifting my lathe.
Its probably only 6-8mm thick steel on the links and I can only just get an M12 bolt in between the links. A cheap motorbike locking chain would do or they sell lose chain in B&Q or something like this from Screwfix is only £14 and 2m is plenty.
Old 7th September 2014, 05:38 PM
Thanks for the input everyone.
Old 1st November 2014, 10:11 AM
Default Rear lower wishbone to upright bolt
Originally Posted by PorkChop View Post
Welcome
Make sure you undo the hub nuts if you're going to refurb the driveshafts/uprights while they're still fitted on the car; it's a lot easier! The front nuts are an unusual size (29mm), the rear nuts can be 29 or 32mm depending on the car.
The whole rear section can be a PITA; the driveshafts can get properly stuck in the uprights and the lower wishbone to upright bolt is exposed, so removal a lot of the time can be problematic.
You'll most likely have an issue with the steering rack fouling the front lower wishbones at full lock and droop; there's lots of examples over in the States where the Miata has been a popular donor car for a lot longer than over here. There are several ways to fix it, which are covered on the forum.
You'll need a custom tank anyway, you can use the MX-5 sender and pump, you might need to modify it. Someone might even have a MX-5 tank for sale
Where in the world are you?
PorkChop,
How did you get the bolt out in the end? My donor has only done 65k, so thought it would be easy, but it's a real bitch. It's basically swimming in WD40, trying to turn it to loosen the damn thing (limited success) and I've even tried a sledge, but that's just damaging the end of the bolt.
Any suggestions welcome.
J
Old 1st November 2014, 10:26 AM
Originally Posted by JasonL View Post
PorkChop,
J
I cut mine off carefully with an angle grinder then pushed the bolt out on a 12 ton press to break the friction then hammered it out with a drift.
Old 1st November 2014, 11:01 AM
PorkChop,
J
I bought a good one off eBay! And cut the rest of the hub off driveshaft carefully.
Old 2nd November 2014, 09:03 AM
Thanks Guys.
I was about to start cutting, but decided to try shock and unlock from Halfords and work it loose with a tyre iron (ironically the right size). Used a piece of the exhaust pipe for leverage and it did the trick, probably because the donor hadn't done that many miles.
Thanks again.
J
Old 10th November 2014, 08:51 AM
Default MX5 VIN plates
Took the VIN plate under the bonnet out and scraped the sticker off the driver's side door well.
Are there any other hidden ones?
Old 10th November 2014, 09:34 AM
I cut the actual vin number out of the chassis too.
