Old 30th November 2014, 12:40 PM
It's dirty cruddy second grade cast ali of course it's a pig to weld, it's not like welding new cold rolled ali sheet it's got a fine sand like grain to it that just disappears when you push the weld pool at it. If it was easy then every body would do it.
Are you going for a new ECU, piggy back or just using the 13-14 deg retard timing trick with that set up?
Old 30th November 2014, 01:28 PM
Hi Phil,
I have a Megasquirt Microsquirt v3 on it already. Basically an MS2 with limited input/outputs but enough to run an MX5 engine. I find it pretty easy to work with.
Old 1st December 2014, 11:08 AM
Adding a turbo isnt cheap but im still trying to save where I can. The injectors of choice for an MX5 turbo install are RX8 440cc yellow injectors. They are a straight swap for the OEM injectors but of course, as this is a known thing, sets of used dirty injectors are £90-£110.
Turns out that Subaru WRX blue injectors are 420cc and are the same as the RX8 yellows except they are 9mm shorter, but a full set cost me £20. I paid £55 to get them re-coned and flowed and im still quids in against the dirty RX8s which would also need re-coned.
Making up some new brackets for the OEM rail seems like a no brainer to me as I have a mill and alluminium so I cut the old mounting tags off the rail and made up these,
Old 1st December 2014, 01:01 PM
Adding a turbo isnt cheap but im still trying to save where I can. The injectors of choice for an MX5 turbo install are RX8 440cc yellow injectors. They are a straight swap for the OEM injectors but of course as this is a known thing sets of used dirty injectors are £90-£110.
Are you running those injectors at 3 bar? Have you upgraded the fuel pump?
Old 1st December 2014, 01:37 PM
Yeah at 3 bar they are 420cc. The standard fuel pump is fine if you are using an aftermarket ECU rather than a higher rate pressure regulator to provide more fuel. It can pump up to nearly 6 bar so 3bar standard + 3 bar of boost if youre crazy enough.
To quote Miata Turbo FAQs.
If you have an aftermarket ECU, the stock pump more than enough to support 300rwhp with the stock regulator.
Old 1st December 2014, 05:08 PM
Oh right, good to know. I didn't know mx5 pumps were so capable!
Old 7th December 2014, 08:24 PM
Couple of steps closer. Got the sump on.
Clearance is miles better now so shouldnt be scraping any humps now.
Also got my charge piping in place.
Waiting on one last silicone T to for the dump valve and need a bottle of oil to refil and I can give it a whirl.
Old 10th December 2014, 05:55 PM
Well it runs again!
I need to upload a new map to suit the injectors as they will be way rich on the old map.
Old 10th December 2014, 07:29 PM
thats going to be a nippy little number.
Old 12th December 2014, 02:44 PM
Hope so but Im going to need to get a new exhaust to make the most of it as mine is 2" Once I have everything in place and I've been running it a while ill get a new DP and exhaust made of 2.5" stainless.
