Old 22nd March 2010, 11:53 AM
rpjg1975 rpjg1975 is offline
Default Rear hub nuts!
Ok, I have managed to get one hub nut off it am stuck! The other side is just spinning although the drive shaft isn't moving. It almost seems that it has been cross threaded on the driveshaft but won't wind back off. Any ideas guys it's doing my head in now?
Cheers guys
Old 22nd March 2010, 11:57 AM
Are you going the right way? some of the hubs are reversthreaded. I think there's a dot punched in if it's the case.. Think it's mentioned in the haynes.
Old 22nd March 2010, 11:59 AM
The drivers side wound off anticlockwise and i'm turning the passenger side the same so.... i think so unless some sneaky sod has put a reversethreaded on on the passenger side! Nothing would surprise me though
Old 22nd March 2010, 12:03 PM
Enoch Enoch is offline
Yup, passenger side is a left hand thread. You will bnotice that the nuts have different coloured locking rings, mine were green drivers side and white passenger side.
Old 22nd March 2010, 12:05 PM
Damn, does that mean i've knackered something if it's spinning the other way? Will have a go the other way
Old 22nd March 2010, 12:10 PM
No you haven't broken anything, you'll just have tightened it on something crazy. The nut is clearly marked as a reverse thread by notches put on the nut.
Old 22nd March 2010, 12:16 PM
Cool, will go and have a play and see if I can get it done. Cheers
Old 22nd March 2010, 12:44 PM
Right, had a go and it's still spinning. It has indeed got white on the locknut bit. Any bright ideas?
Old 22nd March 2010, 12:48 PM
hi Russ,
not trying to cause you probs, but may i ask why are you trying to take the hub nuts off?
Old 22nd March 2010, 12:50 PM
Hi andy,
I understood that they needed removing to remove the rear diff etc? Am I mistaken? Presumed it all needed stripping down when stripping the donor?
