Old 22nd January 2011, 06:36 PM
gaz05 gaz05 is offline
Default Pinto v zetec
I've been looking for a pre 95 1.8 zetec to put in for IVA but been offered a Qreg Carlton Commando kit car with a 2L carb dizzy pinto for £175. It comes with two gearboxes (4 spd) and being based on a cortina I could probably flog the uprights and back axle (and maybe the Reg ) Hasn't been started for 6 years mind.
I'm undecided. What are the pros and cons of both motors. I'm aware that the exhaust exits opposite sides so swaapping at a later date means a lot of work.
Total cost so far
Materials £3,150
Tools £855
Old 22nd January 2011, 06:46 PM
erm.. that sounds like a bargin for the Carlton, I used to want one many years ago.
Old 22nd January 2011, 06:50 PM
aerosam's Avatar
aerosam aerosam is offline
Personally I'd try and get the pinto running before parting with any cash.
Don't forget you need to be able to prove your engine's age to qualify for a non-cat IVA emmissions test, which may be difficult to prove with the pinto as it has already be transplanted once.
If you intend doing swap post IVA anyway, a CVH may be an easier engine to source.
Sorry, I know bugger all about Zetecs.
Old 22nd January 2011, 08:18 PM
I'm not too worried about starting the motor as I would probably freshen it up anyway.
I may not be able to prove identity but should imagine that so long as the number is legible I can prove the age. Hopefully.
I really did see me end up with a 2L zetec eventually so am still undecided.
Total cost so far
Materials £3,150
Tools £855
Old 22nd January 2011, 08:22 PM
I don't think you can loose out for £175 .
probably a good proft to be had!
Old 23rd January 2011, 11:43 AM
Big Vern Big Vern is offline
[quote=aerosam;51767]Personally I'd try and get the pinto running before parting with any cash.
A.S.
It doesn't matter with Pinto's as they stopped fitting them in cars during 1989 and in transits in 1992.
You only need to prove the age of the engine. The age of the vehicle it came out of is generally ignored.
A tired Pinto will cost more to rebuild and there are plenty of good Zetec silvertops still about that you couldbolt straight in.
BV.
Old 24th January 2011, 12:38 AM
swapping the engine on mine now and every day i think to myself why didnt i just put this one in to start with lol.
My Pictures
Old 24th January 2011, 08:49 AM
Yes Ash that's the reason I'm still undecided. I'm still looking for a whole cheap escort or Mondeo so I can use the original ignition/ injection system to save cash. The Carlton offer will be open to me for a long time cos the guy is not bothered whether it sells or not.
Total cost so far
Materials £3,150
Tools £855
Old 24th January 2011, 12:15 PM
Coozer's Avatar
Coozer Coozer is offline
Think if you compared the same car with a zetec you would be well impressed with the extra urgency to rev compared with the lazy characteristic's of the pinto. Not called a boat anchor for nothing
MNR Vortx Build Diary
www.mymnrvortx.blogspot.com/
Old 24th January 2011, 03:21 PM
aerosam's Avatar
I always thought it was because it was all cast iron?
