Old 10th January 2015, 06:41 PM
Rosco Rosco is offline
Got my radiator mounted today while I still had my borrowed nose cone, I will sort the top brackets later
Some rubber grommets off ebay
Then I set about making some spacers for my engine mounts, faced and centre drilled them in the lathe, then drilled
Them through on the pillar drill as my lathes a bit small for drilling
That's the rear mount offered up
And that's the front
Old 10th January 2015, 06:42 PM
I decided to rubber mount my engine cradle, so have used some spare wishbone bushes I had left, I will see what it's like but could
Always make some softer bushes if I need to
Struggling for bolts, hence the washers, there m10x1.25 so not really very comon
I'm going to weld spacer tubes In between the plates
Side engine mount
Ready to tack up tomorrow
Old 11th January 2015, 11:57 AM
dubzter's Avatar
dubzter dubzter is offline
That's some real tidy work there, looks fantastic.
Old 11th January 2015, 05:43 PM
Cheers, pretty pleased with how it's turned out
I looked at other cradles and didn't really fancy mounting on just one bolt either side, I no it's going to be a bit heavier, but I will lose the weight elsewhere if I can
Got it tacked up today and worked out my coolant pipes
And one of the pooch
Old 12th January 2015, 11:06 PM
Busy evening tonight,
My mate tacking up my wishbones
All welded
Rear end assembled again
Might have to remake to top ones to, just because I made them to the book jig that hadn't been up issued although the wishbone drawing had! Argh!!
Popped and got some bits off my mate who runs an ebay shop
Then got it back on the stands and the engine bolted back in
Old 12th January 2015, 11:07 PM
Got loads to do now, I've got everything to get my cooling hoses done, also going to start to look at making an exhaust manifold and a fuel tank
Also sort out my lower engine mount
Old 13th January 2015, 10:15 PM
Got my coolant hoses on tonight
That's the oil cooler return T'ed into the out flow
