Old 8th September 2011, 08:50 AM
brainbug007's Avatar
Default Where does this go?
What is this wire for? Its on the loom between the battery connections and the steering column
and this one, its on the loom by the alternator & crank sensor, next to the lamda sensor
Old 8th September 2011, 12:40 PM
The first photo looks like it is just a general earth wire, is it a brown wire under the black protective sheath? if so I,d suggest attaching it to the chassis .
But then again..... I hate electrics so maybe talking a load of tosh
Old 8th September 2011, 01:05 PM
So would it be safe to say any brown wires with a circle type connection at the end will just be earths that should be attached to the chassis (eg like the lights and the bundle of 4-5 by the fuse box)? Also is it safe to attach more than one earth to the same bolt?
Old 8th September 2011, 03:56 PM
shaun shaun is offline
The first one looks like an earth wire (as HandyAndy said).....I think.
The second one looks like a connection on to one side of the coil....I have a the I4 engine and the coil connection looks like that.....
You can put more than one earth wire on a connection.
Hope this helps.
Shaun
http://www.shaunsroadster.wordpress.com
YOU CAN NEVER HAVE TOO MANY TOOLS!!!!
Old 8th September 2011, 04:32 PM
Yep collumn earth an +12v ignition feed for the coil,
Old 8th September 2011, 08:27 PM
Ok so that's one down with the earth. Not sure what you mean about the +12v ignition feed for the coil though as I'm a bit of nub when it comes to this... Do I put it on something like the starter or where does that connect onto? My engine was a cvh cfi (injection)
