Old 13th October 2012, 07:40 PM
A stop pin as far as I Recall..
Give me a moment.
Old 13th October 2012, 07:43 PM
No Stop pin, it must be internal.
The needle probably needs re-aligining with zero
Old 13th October 2012, 07:45 PM
Thanks TT
Any ideas how?
Old 13th October 2012, 07:50 PM
Pull it off, turn it to 0 and push it back on.
Old 13th October 2012, 08:31 PM
Simples
Next question--I am buying up a few clocks/guages for my post IVA dash.Would any electric impulse type rev counter/tacho work accurately with my sierra cvh. Also is my oil pressure switch fairly easily adapted to a tube for oil pressure guage.
Thanks in advance.
Old 13th October 2012, 11:12 PM
Any wisdom on previous post please?
Old 13th October 2012, 11:17 PM
most reve counters will take a coil input with a swithch on them for the cylinder config
I would use a non capilary electrical oil guage
Old 13th October 2012, 11:44 PM
Does the oil guage need a different sensor to replace the switch
Old 14th October 2012, 04:45 AM
Of course; they usually provide a pressure switch output, too.
Old 14th October 2012, 06:58 AM
Normaly a Tee piece is put into the block, the pressure switch and a pressure sender then fit into that.
The disadvantage usualy of electrical guages is that they only do a 180 sweep and not 280ish like the capillary ones.
