Old 17th November 2012, 11:25 AM
Default some progesss
I managed to fit my brake flexi hoses the other day (made by furore). I am hesitant to fill the system with fluid. I willl need to remove the front flexi's when i attach the bodywork and dont want a mess in my garage..... However i do fancy the idea of taking the car for a quick spin (on a private road ahemm cough).
I have also rec'd 2 grp seats from kit spares in Hull (the biggest box I have ever had delivered - my son immediately made it into a submarine). They seem to be good quality, however the way the harness holes have been trimmed seem to make it impossible to fit the edging strip. Looks like I will have to ask santa for a Dremmel! Could be handy with the bodywork as well.
Has anyone else fitted these seats? If so what kinds of runners fit? The seats seem to have a bulge underneath so they presently dont sit completely flat on the floor. I was hoping not to use a runner on the passenger seat to save a bit of weight.
Old 17th November 2012, 11:36 AM
Just a quick mention that I had to get a certificate of Conformance for my brake lines (Also from Furore) to pass the IVA.
Old 17th November 2012, 11:43 AM
Did Russ provide this free of charge? I am well impressed with the service so far
Old 17th November 2012, 12:13 PM
I'd expect so. I sorted it out myself, a long with many other items of paperwork the IVA man wanted to see to prove stuff was suitable if it wasn't marked as such (fuel filler hose, carb rubbers and brake lines). Receipts don't do it, they wanted actual proof.
Old 29th January 2013, 09:36 PM
Default Broken bolts in thermostat housing aghhhh!
I popped out for 2 mins tonight (braving the cold) to do something on the car. I thought an easy job would be to change the thermostat. Both of the bolts sheared off. Has anyone got any ideas of how to remove them??? Here is a picture. I was contemplating drilling them out and using 2 long bolts.
Old 29th January 2013, 09:47 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
Will the thermostat housing slip over the broken studs
If they will take housing off place washer over stud weld stud to washer then weld a nut to the washer
The heat generated should make the stud easy to remove cause the alli will expand with heat twice as much as the steel
Hope this helps
Old 29th January 2013, 09:53 PM
I cannot get the thermostat housing to move. The bolts seemed to be really soft as though they were aluminium.
Old 29th January 2013, 10:19 PM
I've managed to remove the thermostat cover and I have about 4-5mm of bolt showing. Any other way of doing it other than welding?
Old 29th January 2013, 11:04 PM
vmax1974's Avatar
As long as you can apply heat and grip and turn the stud it should come out
I assume you have handed the welder back if you do need one you could come borrow mine for a day or 2
Old 30th January 2013, 12:18 AM
rapidtornado's Avatar
I had a similar issue on my manifold block, the way I tackled it was to drill a 3-4mm hole in the centre then slam an oversized torz bit into the hole. Hit the torx bit fairly hard to try and 'jar' the bolt, then put a socket it on it and wind it out... it may not work if the material is as soft as you say but it worked for me in the past when all else fails
hence why me and half pint nick named the car 'bolt'...
