Old 6th April 2015, 06:14 PM
Rosco Rosco is offline
Rear diagonal done
A shot from the rear, also a bit of artwork put up!
Also I've set my self a date of Easter next year to be Iva'ed and on the road
Old 12th April 2015, 02:48 PM
This weeks progress
I started working out where my lower harness mounts were going according to the msa blue book
I've changed the book design a little, tacked in
Centre two
Old 12th April 2015, 02:49 PM
Upper seat brackets done, I no the top edge doesn't need a radius behind the seat, but it looks neater I think
Just need some side to side spacers sorting and some correct length bolts
Next throttle cable sorted and temp return spring and the studding through the top is a temp forward stop
Full throttle
Old 12th April 2015, 02:50 PM
Clutch cable
Full clutch
I made two tubes to hold the outer cables
Next job, the rest of the roll cage, I've decided to mount the front hoop on the outside, as bashing my leg on it all the time not my idea of fun
I mocked up the scuttle panel, and worked out a mounting plate
The tube will mount to a bit of tube on end with two more bolts so it meats msa spec, once the front hoops in place I will sort my roof bars and door bars out
Old 12th April 2015, 07:29 PM
scutter scutter is offline
Dude, still mighty imprressive. Makes mine look like it's being built in a cowshed.
ATB Dan.
Old 12th April 2015, 07:46 PM
Ianr Ianr is offline
Daren't put any pics of my poorly built badly engineered thing on here, it'll be compared to this engineering master piece.
Brilliant bit of work Rosco - not that much different in build progress to mine really but I want to get mine on the road for 2016 kitcar show, fancy a race???
Old 12th April 2015, 11:11 PM
dubzter's Avatar
dubzter dubzter is offline
Awesome work, looking forward to seeing how your roll bar works out as that is something that is really playing on my mind
Old 13th April 2015, 08:56 PM
ATB Dan.
Lol cheers, just a bit of floor paint makes all the difference
Yeah go on then!
Yeah it is mine to be fair, I think I'm going to mount it on the outside i think and welded on, I've had a quick draw up of it, but I'm going to mock it up with plastic pipe while I'm sat in the car
Old 14th April 2015, 09:21 AM
Excellent tweeks to original Gibbs design.
What would it be like to syphon off all the excellent upgrades builders have made and put them into one roadster .
Old 14th April 2015, 10:21 AM
vmax1974's Avatar
vmax1974 vmax1974 is offline
A bit like rosco"s build am guessing watching it shape up in awe
