#161
here,s another photo that might help....
#162
thanks for the photos, i should be able to fabricate my engine mounts soon now.
i still cant believe what i was trying to do earlier.. i even tried putting bricks behind the rear wheels to stop it moving, and i pushed on the engine as hard as possible to try to move it. ![]()
my build pics |
#163
no prob,
in the above photo the only part of the engine/box that is lower than the bottom chassis rails is 25mm of the gearbox bell housing, the sump of the engine is flush with the lower chassis rails, but i have used a shortened sump from a zetec engine, so it all depends on how much your sump is shortened by, to how much clearance you have below the engine. when fitting the engine/box..... try to keep the output shaft of the gearbox level with the center of the diff flange .cheers andy |
#164
I fitted my engine & box in as a single unit. Just couldn't manage to roll the chassis forward as I was gently lowering it all down. Spent ages looking for snags, then noticed I still had a wheel chock under the back wheel. ![]()
I am not a complete idiot...........Some of the parts are missing !! Ronnie ![]() www.roadster-builders.co.uk |
#165
my build pics |
#166
well today i half gave up for the day, firstly i cut out the bit i forgot to cut out for fitting the engine. I then started reaming the bottom of the front hubs to fit the ball joints, after about 35 min of continuous reaming and a VERY painful arm i stoppedd and left it for a few hours, i then weled on the shock bracket on the lower front wishbones but only just realised that it was meant to be 300mm from the centre of the bush tubes, not 300mm from the end of the wishbones, so will grind off the welds tomorrow and re weld them on. i also stared putiing on all the front running gear, but wasnt sure which way around the mushroom insert was meant to go, but i think the hole in it is meant to be as far in as possible. I then treid to fit the steering rack extensions, but they wont go on all the way as the rack starts spinning then. how do i stop the actual steering rack arm from spinning? today has been abit of a pain as most things that could go wrong went wrong!!!
my build pics |
#167
the reaming should tke approx 10 mins per upright, just keep checking that you don,t go too far with the reaming.
as for steering extensions, are they the ones that are too long? mine are from Rally Design & fit like a glove, check the internal depth of the thread in the extension in relation to the length of thread thats on the actual steering rack, they may not be matching. the mushroom is to sit fully into the upright with the offset hole towards the front of the car. hope this helps. andy ![]() |
#168
ok, ill rotate the mushrooms tomorrow and hopefull put the front wheels on and engine mounts in. Thanks!
my build pics |
#169
if the extensions you have are made to book spec then i think they are too long, if i remember correctly when you fit them & put the wheels on then the wheels will be pointing outwards instead of straight on , not 100% sure but somebody else had a similar problem,
what total length are your steering rack extensions? andy ![]() |
#170
ok my rack total extension is 185mm, the thread depth of the extension is enough to go over the whole thread of the mk2 escort rack.
my build pics |
| Thread Tools | |
| Display Modes | |
