Old 9th February 2010, 10:15 PM
the clamp will fit its meant to be tight. the packer under the bigger bracket only needs to be 1.5-2mm on your front upper suspension brackets i welded a little bit of 3mm plate on to brace them as they are not central.
Old 9th February 2010, 10:47 PM
gingea1pom's Avatar
Ash,
That makes perfect sense about the upper suspension bracket. I’m thinking two triangular gussets (stop sniggering at the back) would do the trick.
I have just had another bash at the steering clamp and it went on a little further. My rack is brand new and there might be an excess of paint on it!
Cheers Ginge
Build Pictures
Old 12th February 2010, 04:55 PM
gingea1pom's Avatar
11 Feb
I spent quite a bit of the day fabrication a bespoke engine stand to enable me to manoeuvre the engine and gearbox around the garage on a trolley jack without it falling over, also it will allow to fine adjust the position of the engine and gearbox in the car.
[IMG][/IMG]
I managed to get the engine and box ‘into’ the chassis, it was a little nightmare as I had already fitted the diff which made the back end really heavy, so to get the gearbox up the transmission tunnel I had to raise the front of the chassis and lower the rear. The opposite of how you would do it if you had an engine lift..
[IMG][/IMG]
It is roughly in position now and needs some measuring to get it perfect, I am going to be stuck if the 5mm steel I ordered doesn’t turn up soon because engine mounts are next.
Sierra is still on the drive!
12 Feb
Only had a couple of hours in the garage after going to ‘sharing assembly’ and before school pick up.
I concentrated on getting the output shaft of the gearbox bang in line with the input of the diff, ensuring the gear stick still goes in reverse and the reverse light switch connecters are still accessible, then I welded on the gearbox mounts (I added some ‘gussets’ to them just to beef things up a little) with the gearbox attached. As for the engine mounts, the steel hadn’t turned up so I sacked it at 1pm and watched CSI.
[IMG][/IMG]
The steel turned up at 2.30pm so tomorrow (I know Saturday and I get to go into the garage I think it is only because it is half term) I am going to mock up the complete steering system to make sure the driver’s side engine mount doesn’t encroach. I have finally admitted defeat and TR5 has got to go, I offered up the bike carbs and there is no way they will go on with it in place. Another example of Ginge thinking he knows better, rear hub nuts and now TR5, you would think I would have learnt by now.
[IMG][/IMG]
Sierra is still here.
Pictures arent working pop back later
Picture still not working properly dam it
I think I have got it now
Build Pictures
Last edited by gingea1pom : 12th February 2010 at 05:51 PM. Reason: Photo bucket not playing the game
Old 12th February 2010, 05:58 PM
Tatey's Avatar
Tatey Tatey is offline
Looking really good Ginge. Although you've missed a weld on one of the uprights, look to the right of the engine in the last pic .
Old 12th February 2010, 06:15 PM
gingea1pom's Avatar
Mate,
You must have eyes like a Hawk! I thought I had found the last missed weld the other day, thanks.
Cheers Ginge
Build Pictures
Old 12th February 2010, 06:40 PM
looking great Ginge, nice work
did you have the .........."looks like a car now" feeling?
cos i know i did when put the engine / box in
Tatey........ i dropped a needle at the unit today....fancy coming over & finding it for me ????
Old 12th February 2010, 06:52 PM
Brilliant stuff Ginge
I am pleased you posted those pictures of the gearbox position ...... It has certainly made things a lot clearer for my Zetec install
As I have said before ..... Those pesky Pixies sneak in the garage overnight & steal those welds
Old 12th February 2010, 06:53 PM
gingea1pom's Avatar
Andy,
It defiantly feels more like I am building a car now and not just cutting and welding steel together, although I seem to have to weld something every day it is interspersed with engines and steering columns.
Ronnie,
I was really convinced I had got the last of the Chassis tube welding done, can’t believe I missed it.
Cheers Ginge
Build Pictures
Last edited by gingea1pom : 12th February 2010 at 06:56 PM. Reason: Ronnie typing whilst I was
Old 12th February 2010, 07:14 PM
If it's any consolation ...... I missed that exact same weld .... Twice
I wonder if anyone has counted how many welds there are on the Roadster chassis tubes !!
Old 12th February 2010, 07:29 PM
Hmmmmm........... now there,s a question NO i don,t know that answer as i spend more time cutting the chassis,s than welding them
Ginge....
yeah , know what you mean.....its no longer a climbing frame for the kids or a "chinese puzzle"........its a CAR .
nice work mate .
