Old 9th May 2015, 09:24 PM
Rosco Rosco is offline
I no some people won't like it, but I got the spoiler for nothing, it's only for a mess about, that's why I've done it to bolt on and off easily
Today's job was to start making a bead roller like below
Bits required
Old 9th May 2015, 09:25 PM
Machining the blocks to house the bearings on my dad's home built cnc
Last up my dads started on my dash buttons, we're having a go using an ARDUINO, it's a programable chip with ins and out, they can be used with switches, sensors, relays just have a look on ebay to see what's available, the boards are about £8 and everything else like switches are pence, it's programmed from a PC through USB, so things like indicator flashing can be programmed, if it works out ok it will all be soldered and put in a little project box
Old 16th May 2015, 09:09 PM
Steady progress this week I think
Horns mounted
Headlight mounts made
I stripped the whole chassis down so I could lift it outside, I needed to cut the front shock mounts off as I had got them in the wrong place, to far back by about 10mm
Old 16th May 2015, 09:10 PM
My garage from outside while it's empty
Headlights on
Old 16th May 2015, 09:11 PM
Lower engine mounts tacked on
Next up I made some threaded bosses for my wing mirrors
Also made myself a list, my main aim is to get the chassis ready for powder coating
Old 16th May 2015, 09:46 PM
Looking fantastic as normal.
Add the vin number to pre powder coat.
With your digi dash. How will you mount the speedo pickup?
Earth points. I used rivnuts but others have welded bolts onto the chassis.
Old 16th May 2015, 10:10 PM
Cheers, some good points there,
Do I have to apply for a vin number?
I will check with the dash specs,
Also I will get some bolts welded on
Thanks for the input
Old 17th May 2015, 05:52 PM
Cheers, my dad's made good progress on the dash circuit, if you click the picture below its a video
There's still a bit to do but I think he's sorted the hardest bits of code
Also I've sorted my steering shaft out with some thick walled tube, I heated it up to get the shaft in, just needs tiging around the ends and possibly a few pins
Old 17th May 2015, 08:38 PM
You now need to apply directly to the dvla Swansea
There is a handy letter at the bottom of this post
Also someone mentioned roll pinning the steering extension. I did that and welded the pin so it will never come out. The inspector didn't look at but they are all different. 10mins work or £90 retest fee and the effort getting there.........I know which I went for.
