Old 14th February 2012, 08:44 PM
Eternal Eternal is offline
http://www.ebay.co.uk/itm/MAZDA-RX7-...83911117022469 Possible intercooler that will fit
Skyline Roadster
Old 15th February 2012, 12:21 PM
Have you looked up mr2 intercoolers?
They are small and fat, may do the job
Old 16th February 2012, 08:00 PM
After a load of research and a quick chat with Red16 from passion ford.
Have conculded the best option would be.........
RX7 FC3S
16" fan
Civic Rad 92-00
Pics from Red16's build
My only real worry is the fact that the civic rad might not be able to handle the load form the RB25DET. Not sure what i can do apart from possibly install a 2nd radiator somewhere or two oilcoolers to help bring down the temps a little.
Skyline Roadster
Old 17th February 2012, 08:33 AM
MarkB MarkB is offline
I would of thought the rad is never going to get cool air mounted like that, you may need to duct air into and out of it. Neat looking rads though
Old 21st February 2012, 09:45 PM
Found ths article and it refers to a water to air charge cooler, never heard of or seen one before but are very compact. there is one at the back of this engine.
http://www.hotrod.com/techarticles/e...k/viewall.html
edit found this one which is good for 300 hp http://www.frozenboost.com/product_i...39391500bf49d1
Old 21st February 2012, 11:19 PM
here is the charge cooler I am going to use
Old 22nd February 2012, 12:16 PM
The celica gt4 (94/99) charge cooler can handle a good amount of power for its size, its a common upgrade on the mr2s when you start going towards the 400bhp mark
Just means another rad and water circuit though
Old 2nd March 2012, 04:22 AM
jenks's Avatar
jenks jenks is offline
When using a ST205 GT4 water/air charge cooler (or any higher BHP charge cooler) you need quite a big radiator to get them working properly, like smal car size... A lot of the MR2 swaps use a Rover Metro radiator! plus there's the extra plumbing/complexity to consider
... For simpicity's sake a nomal air/air intercool would be the way to go. Top mount may be an option if you don't mind having a big bonnet scoop. The later 3S-GTE's in the ST215 went back to using air/air topmounts
Old 2nd March 2012, 07:27 AM
loony's Avatar
loony loony is offline
But there must be reason why top mount air/air intercoolers are often called "interwarmers" - especially in car like Roadster, which rather don't go at high speeds, because of aerodynamics.
So - I think water/air intercooler could be very good way - small and efficient.
Lucas
ZX9R BEC Haynes Roadster - build cost so far: £1125
My build thread
"Whatever you can do or dream you can, begin it. Boldness has genius, power, and magic in it." J.W.Goethe
Old 7th March 2012, 10:23 PM
Big thanks to Skov for the great price on the fuel sender. If anyone wants a standard 1.6 mk1 mx5 fuel pump give me a shout!
As you can see a nice Walbro 255lph RX7 GSS342 33911-3 fuel pump. All i need now is the plug for the sender lol
Skyline Roadster
