Old 14th January 2013, 02:01 PM
iDriver iDriver is offline
Default ABS ? Power Steering?
Hi Guy's,
Ok, here is where I m at, I recently bought a part built venom GT2 kit which has all Granada breaks and hubs front and rear installed. It has a ford v6 installed as is the Gearbox, diff, powersteering rack, wiring loom and steering column.
The frame is made from box section of about 40mm sq.
It was bought for the right price as a donor vehicle and I would be quids in even if I only use the 4 corners, Diff and shafts.
I have even looked at chopping the chassis so it is more or less the same shape as a haynes roadster, all be it the steelwork would be heavier, there would be less of it. Still thinking on that aspect of it..
Anyway, my questions are these at present, do you lot who use don parts from vehicles that had ABS actually reinstall the ABS on your kits or just bin it and stick with good old standard brake systems?
Do any of you use power steering?
Mark
