Old 23rd July 2013, 08:36 AM
The only ones that will notice that they obscure the headlights will be the ones you runover and they don't count
Old 26th July 2013, 10:08 AM
davidimurray's Avatar
Just remember that for IVA they must be a MAX of 400mm from the edge of the vehicle. I.e. the outside of the cyclewing. Headlights are the same.
I made mine quite simply with a length of copper pipe, some nuts soldered in the end and a bolt with a hole up the middle to secure it to the nose. The nut has a plain washer and a rubber tap washer to protect the fibreglass. Once the nuts were soldered in the end I profiled the end with a file so it sat sqyare and horizontal against the nose.
